6813 Discusiones
ippsWinKaiser_32f_I fails for many length & alpha values
thomtek
Novato
1.908 Vistas
I'm usingippsWinKaiser_32f_I(Ipp32f* pSrcDst, int len, float alpha) from v7.0.5. On both x86 and x64 systems.
I have found that if the value"prod = alpha * (len-1)/2"> ~39 (where len and alpha are arg values to the function), the functionreturns an error code and does not calculate the requested window points. The error code and string returned is (-39), "ippStsHugeWinErr: Kaiser window is too huge".
For example, for len = 40, any alpha > 1.9 causes the function error. For len = 100, alpha > 0.77 causes the error. The _64f version does not appear to have this problem.
Here is example code for len=40:
void Test_ippsWinKaiser_32f_I(void)
Ipp32s LEN = 40; // LEN can be varied
Ipp32f* pDst = ippsMalloc_32f(LEN);
for (Ipp32s n=0 ; n
pDst = 0.0f;
Ipp32f beg=36.0f, end=42.0f, step=1.0f; // range to trap error, happens around prod=39
for (Ipp32f prod=beg ; prod<=end ; prod+=step) // loop thru range in steps
Ipp32f alpha = prod / (Ipp32f)(LEN-1)*2.0f; // calc alpha related to prod & LEN
IppStatus s=ippsWinKaiser_32f_I(pDst, LEN, alpha);
printf("Len = %i, Prod = %.5f, Alpha = %.5f", LEN, prod, alpha);
if (s != ippStsNoErr) // print when error detected.
printf(" ---> err=%i, msg=\\"%s\\"",
(int)s, ippGetStatusString(s));
printf("\\n");
ippsFree(pDst);
The output in this case is:
Len = 40, Prod = 36.00000, Alpha = 1.84615
Len = 40, Prod = 37.00000, Alpha = 1.89744
Len = 40, Prod = 38.00000, Alpha = 1.94872 ---> err=-39, msg="ippStsHugeWinErr: Kaiser window is too huge"
Len = 40, Prod = 39.00000, Alpha = 2.00000 ---> err=-39, msg="ippStsHugeWinErr: Kaiser window is too huge"
Len = 40, Prod = 40.00000, Alpha = 2.05128 ---> err=-39, msg="ippStsHugeWinErr: Kaiser window is too huge"
Len = 40, Prod = 41.00000, Alpha = 2.10256 ---> err=-39, msg="ippStsHugeWinErr: Kaiser window is too huge"
Len = 40, Prod = 42.00000, Alpha = 2.15385 ---> err=-39, msg="ippStsHugeWinErr: Kaiser window is too huge"
0 kudos
4 Respuestas
igorastakhov
Nuevo Colaborador II
1.908 Vistas
it's designed behavior:
#define IPP_MAX_EXP64f 308
#define IPP_MAX_EXP32f 38
#define IPP_HUGE_WIN_RET(alpha,N) \
IPP_BADARG_RET(fabs(alpha)*(N-1)/2 > IPP_MAX_EXP64f, ippStsHugeWinErr)
#define IPP_HUGE_WIN2_RET(alpha,N) \
IPP_BADARG_RET(fabs(alpha)*(N-1)/2 > IPP_MAX_EXP32f, ippStsHugeWinErr)
Take a look at the Kaiser window formula and you'll uderstand the reason of such limitation. If you really need so huge alphas - use 64f flavor of this function
Igor
sudoLife
Nuevo Colaborador I
1.697 Vistas
Could you explain why that limitation is in place?
Is it because of the maximum precision?
I need a Kaiser window like the attached png for 1024 points.
In python, this would be numpy.kaiser of len 1024 and alpha coefficient of 6.3.
sudoLife
Nuevo Colaborador I
1.648 Vistas
Sorry, I meant beta of 6.3, since that's what's used in numpy. Alpha would be around 2.
thomtek
Novato
1.908 Vistas
Thanks, that makes sense. We'll handle it appropriately now that we know the reason.
It would be helpful ifthis restriction could be added to the Ref manual.
Responder
