6815 Discussions
link error with IPP 5.3, gcc 4.2.1, x86_64, MacOSX 10.6
oku
after upgrading MacOSX to 10.6 and switching my local development target architecture to x86/64 bit I get the following link error on my standard project:
ld: in /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a(piswap_split_mx_ippiSwapChannels_8u_C4IR.o), ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
What can I do about this?
Hints:
Versions: IPP5.3.1.056, gcc 4.2.1 on MacOSX 10.6 build 10A432
lipo -info /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a
yields
Architectures in the fat file: /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a are: x86_64 i386
This used to work before.
Gennady_F_Intel
Quoting - oku
Hints:
yields
Gennady_F_Intel
Oliver,
Please try to choose dynamic linking when you built the code on SnowLeo with IPP 5.3.
It seems that the issue you encountered causing by incompatibility with SnoLeo binutils ( partically in ld tool ).
--Gennady
oku
Hi Gennady,
thanks for answering. In the meantime, I figured out, how to set my build system back to use gcc 4.0 and 32 bit. This way, I can build a working 32 Bit application and link against the ipp, just like before - on Mac OS X 10.6.
I don't think, deploying all those dynamic ipp libraries is an option, but I will check anyway.
Until then, we will not be able to build a modern 64-bit-Cocoa-Application, which uses ipp.
Pavel_B_Intel1
Hello!
Could you show the link string for x86_64 MacOSX 10.6? I've tested theIPP 5.3 libraries on MacOSX 10.5 x86_64 - all ok.
Pavel.
oku
It's not a Mac OS X version issue, but a gcc version issue. The link string looks the same. Using the gcc 4.0 linker, it works, using gcc 4.2.1, it doesn't. Maybe, you can reproduce it on Mac OS X 10.5 as well, by setting CC=gcc-4.2 in the makefile (or Xcode project or whatever you use). The onlyMac OS Xdifference is, on 10.6, gcc 4.2.1 is the default and /usr/bin/gcc links to /usr/bin/gcc-4.2 instead of /usr/bin/gcc-4.0.
Maybe there is an incompatibility with the .o and .a object formats between the bin utils of the two gcc versions. I think, Intel could just recompile and relink the libraries with the newer tools and distribute those, too. This could be done, when finally updating ipp to 6.x (!) for the Mac OS X platform, since I don't think the money we payed is old and incompatible with current goods...
Note: On Linux, using ipp with the gcc 4.2.1 tools works. So, the incompatibilty probably lies within the OS specific object format (elf vs. Mach-O).
Artem_V_Intel
Quoting - oku
I compiled a simple test on 64-bit Mac OS X 10.6 and doesn't obtain any issues. You may see the version of compiler I used and my linking line below:
bash-3.2# gcc --version
i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5646)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
bash-3.2# gcc -o test_em64t_static test2.c -I/Library/Frameworks/Intel_IPP.framework/Versions/5.3.1.056/em64t/include -L/Library/Frameworks/Intel_IPP.framework/Versions/5.3.1.056/em64t/lib -lippiemerged -lippimerged -lippcore
Probably it will helps you. If not, could you please provide exact link line you use?
Art
oku
Art
Art,
thank you for trying, this is good news! I tried a simple sample for myself (just called ippiGetLibVersion()) and it worked as well!
Reproducing the exact situation I had last week, is a rather lengthy process (includes building Qt from the sources), and I don't have enough time left right now, so I will do it first thing tomorrow morning.
Thanks again,
oku
oku
Aha! Calling an actual image function shows the error:
I used this test program:
#include
int main (int argc, char **argv)
const IppLibraryVersion* version = ippiGetLibVersion();
const Ipp8u* pSrc = 0;
IppiSize srcSize = {0, 0};
int srcStep = 0;
IppiRect srcROI = {0,0,0,0};
Ipp8u* pDst = 0;
int dstStep = 0;
IppiSize dstRoiSize = {0,0};
double xFactor = 0;
double yFactor = 0;
int interpolation = 0;
IppStatus status = ippiResize_8u_C3R (pSrc, srcSize, srcStep, srcROI, pDst, dstStep, dstRoiSize, xFactor, yFactor, interpolation);
return 0;
...and compiled and linked it using this line:
gcc-4.2 -arch x86_64 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/ -lippiemerged -lippimerged -lippcore -o ippTest
which led to:
ld: in /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib//libippimerged.a(piresnn_split_y8_ownResize16plN.o), ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
collect2: ld returned 1 exit status
Artem_V_Intel
Quoting - oku
#include
int srcStep = 0;
Ipp8u* pDst = 0;
int dstStep = 0;
double xFactor = 0;
double yFactor = 0;
return 0;
which led to:
I attachedtest case with makefile to this post. I built and run this example successfully. Could you please build it on your side?
Art
P.S. To unpack this archive please invoke the next command:
tar xzvf ipptest.tar.gz
It will create directory ipptest with makefile and test2.c files.
oku
Your sample works. The output is:
ippiSwapChannels_8u_C3R PASSED
SRC
255 0 0 255 0 0 255 0 0 255 0 0
0 255 0 0 255 0 0 255 0 0 255 0
0 0 255 0 0 255 0 0 255 0 0 255
DST
This is interesting. There are functions which work, and some which don't? Did you in turn try my sample as well? The Resize call is one of those we actually use in the project, so that really matters.
Pavel_B_Intel1
Quoting - oku
SRC
DST
Hi Oliver!
Unfortunatelly I don't have MacOSX 10.6 right now and can't reproduce your sample, but as I can see:
Artem uses ippStaticInit() function before using any other IPP functions and it is correct. The emerged + merged librararies - are the static dispatcher and merged static library and you should initialize static dispatche by calling ippStaticInit.
Please try to call ippStaticInit function before.
Thanks, Pavel
oku
Quoting - Pavel Berdnikov
Hi Oliver!
Thanks, Pavel
I did that and the linker still can't link:
main.c:
#include
ippStaticInit();
int srcStep = 0;
Ipp8u* pDst = 0;
int dstStep = 0;
double xFactor = 0;
double yFactor = 0;
return 0;
command line:
gcc-4.2 -arch x86_64 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/5.3.1.056/em64t/lib -lippiemerged -lippimerged -lippcore -o ippTest
ld: in /Library/Frameworks/Intel_IPP.framework/Versions/5.3.1.056/em64t/lib/libippimerged.a(piresnn_split_y8_ownResize16plN.o), ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
...as expected, because not calling the init function may lead to runtime errors, but not to link errors.
I did some more tests, and found out, it does not depend on the gcc version. These command lines work:
gcc-4.0 -arch i386 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/ -lippiemerged -lippimerged -lippsmerged -lippsemerged -lippcore -o ippTest
gcc-4.2 -arch i386 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/ -lippiemerged -lippimerged -lippsmerged -lippsemerged -lippcore -o ippTest
gcc-4.2
-arch x86_64 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/Libraries -lippi -lipps -lippcore -o ippTest
These don't:
gcc-4.0 -arch x86_64 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/ -lippiemerged -lippimerged -lippsmerged -lippsemerged -lippcore -o ippTest
gcc-4.2 -arch x86_64 main.c -I /Library/Frameworks/Intel_IPP.framework/Versions/Current/include/ -L/Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/ -lippiemerged -lippimerged -lippsmerged -lippsemerged -lippcore -o ippTest
So, unlike, what I suspected earlier, both, gcc 4.0 and 4.2 work with static libraries when targeting the 32 bit architecture on MacOSX 10.6, and fail, when switching to the x86_64 architecture. But this works as well, when using dynamic linking.
Pavel_B_Intel1
Hi Oliver!
Yes it is the tools conflict, I can reproduce this situation. I'll investigate it and report you about result.
Thank you, Pavel
Mikael_Grev
FYI, I have problem with this in 10.6 as well.
Cheers,
Mikael
Mikael_Grev
Hello again,
Have you made any progress on this issue? I would really like the 64 bit compliation. For me both 32 and 64 bit works on 10.5 but only 32 bit works on 10.6. 64 bit give me the error in the original post.
Btw, I use the 6.1u1 version with the IPP compiler. Static linking (can't go dynamic).
Cheers,
Mikael
Pavel_B_Intel1
Hello, the investigaion of this problem shows incompatilbe between compiler and ld from MacOSX 10.6. No such problem on MacOSX 10.5. I don't know yet is it theproblem of compiler or it is theproblem of ld. It is inverstigating right now.
I could suggest only one way rign now: use MacOSX 10.5 for linking your application. It works well.
Pavel.
Mikael_Grev
Pavel.
Thanks Pavel.
oku
Pavel.
Hi Pavel,
what about the other way round? If you create the static ipp libs on 10.6, canyou link them on 10.5? If this is the case, Intel could just distribute new libs (created on 10.6).
oku
Pavel_B_Intel1
Quoting - oku
Hi Pavel,
oku
Hi All!
Unfortunatelly it doesn't help, the simple example:
$ sw_vers
ProductName: Mac OS X
ProductVersion: 10.6
BuildVersion: 10A333
$ icc -V
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20090325
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
$ cat test.c
#define CHANNELS_C1 1
#define CHANNELS_C3 3
#define CHANNELS_AC4 4
#define MAX( a, b ) ( ((a) > (b)) ? (a) : (b) )
__inline float Max3Vert_32f(const float* src, int srcStep)
float x = MAX(*src, *((float*)((char*)src+srcStep)));
return MAX(x, *((float*)((char*)src+2*srcStep)));
__inline float Max3_32f(const float* src)
float x = MAX(src[0], src[1]);
return MAX(x, src[2]);
int myfunc( const float* pSrc, int srcStep, float* pDst, int width)
int c;
float local[CHANNELS_C3*3];
int locIndex= 0;
for(c=1; c local[locIndex] = Max3Vert_32f(pSrc, srcStep);
local[locIndex+CHANNELS_C3] = Max3Vert_32f(pSrc+1, srcStep);
local[locIndex+CHANNELS_C3*2]= Max3Vert_32f(pSrc+2, srcStep);
pDst[0+CHANNELS_AC4] = Max3_32f(local);
pDst[1+CHANNELS_AC4] = Max3_32f(local+CHANNELS_C3);
pDst[2+CHANNELS_AC4] = Max3_32f(local+CHANNELS_C3*2);
locIndex++;
if(locIndex>2) locIndex = 0;
pSrc += CHANNELS_AC4;
pDst += CHANNELS_AC4;
return 0;
$ icc -c test.c -o test.o
$ echo -e "_myfunc" >lib.script
$ libtool -dynamic -arch_only x86_64 -exported_symbols_list ./lib.script test.o -o libmytest.dylib
ld: in test.o, ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
libtool: internal link edit command failed
go to the MacOSX 10.5:
$sw_vers
ProductVersion: 10.5.6
BuildVersion: 9G66
And try to link the same object into dynamic library:
$libtool -dynamic -arch_only x86_64 -exported_symbols_list ./lib.script test.o -o libmytest.dylib
No problem, recompile this sample on MacOSX 10.5 and link again:
$icc -V
$icc -c test.c -o test.o
No problem.
I don't know: is it the problem of the Intel compiler or the problem of new ld in MacOSX 10.6, but the problem is on the MacOSX 10.6 and no problem on the MacOSX 10.5.
Because right now the single way to use ld from MacOSX 10.5
Pavel
oku
Yes, you have proven (like me), that a static IPP library, which was created on MacOSX 10.5 (or before), can not be used on MacOSX 10.6. But maybe a static IPP library created on MacOSX 10.6 can be linked on MacOSX 10.5?
