6815 討論
link error with IPP 5.3, gcc 4.2.1, x86_64, MacOSX 10.6
oku
初學者
2,677 檢視
after upgrading MacOSX to 10.6 and switching my local development target architecture to x86/64 bit I get the following link error on my standard project:
ld: in /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a(piswap_split_mx_ippiSwapChannels_8u_C4IR.o), ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
What can I do about this?
Hints:
Versions: IPP5.3.1.056, gcc 4.2.1 on MacOSX 10.6 build 10A432
lipo -info /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a
yields
Architectures in the fat file: /Library/Frameworks/Intel_IPP.framework/Versions/Current/lib/libippimerged.a are: x86_64 i386
This used to work before.
0 積分
34 回應
Pavel_B_Intel1
965 檢視
Quoting - oku
Yes, you have proven (like me), that a static IPP library, which was created on MacOSX 10.5 (or before), can not be used on MacOSX 10.6. But maybe a static IPP library created on MacOSX 10.6 can be linked on MacOSX 10.5?
It doens't dependon which version of MacOSX used for compiling, I compile my test.c on MacOSX 10.6 and the problem are. It depend only from Intel compiler and version of ld. It is the reason why I suggest to use MacOSX 10.5 for linking your application.
I don't know what the reason of problem: Intel compiler or new version of ld, it is investigation right now.
Pavel.
Mikael_Grev
初學者
965 檢視
Pavel,
Do you work at or for Intel? If not, is there anyone at Intel that is looking at this?
I want my Snow Leopard.
Cheers,
Mikael
oku
初學者
965 檢視
Quoting - Pavel Berdnikov
Maybe I didn't make myself clear enough: I was talking about the ipp library itself. Genrerally, static libraries created on MacOSX 10.6 can of course be linked on MacOSX 10.6!
I do not use the Intel compiler at all. I am using gcc for compiling, as well as for linking, so the Intel compiler can not be the problem when USING the library. It CAN on the other hand be the problem when CREATING the static IPP libs (I guess, Intel use their own compiler for compiling the IPP).
I can not test this myself, since I would need the IPP source code. Only somebody at Intel with access to the IPP source code can do this: Create the static IPP libs on MacOSX 10.6 using the bin utils available there. I am almost sure, those could be linked on MacOSX 10.6. The only question would be, could those be linked on MacOSX 10.5 as well? If this is the case, Intel could distribute those and all would be well.
Quoc-An_L_Intel
965 檢視
This issues looks like it's related to a known issue with the compiler documented here. We found this problem during the 11.1 compiler beta, and the compiler / compiler runtime libraries was fixed during the 11.1 beta. This was both a problem with the compiler, and a change in the ld tool for OSX 10.6.
It looks like the performance libraries are built with an older compiler.
Mikael_Grev
初學者
965 檢視
Quoting - Qale (Intel)
Hello Qale,
Is there any official (or unofficial, which I won't hold you to) date for an update that fixes this?
Cheers,
Mikael
Quoc-An_L_Intel
965 檢視
Quoting - mikaelgrev
Hello Qale,
Cheers,
Mikael
No datethat I know of, I only saw this thread today. The performance library folks are aware of this. You should file a bug at https://premier.intel.com to get update on a fix.
Quoc-An_L_Intel
965 檢視
If possible, try linking against the dynamic version of the library to see if that works for you.
Pavel_B_Intel1
965 檢視
Hello Qale,
Cheers,
Mikael
Hello Mikael!
The IPP 6.1 gold will be released with fixing thebug for MacOSX 10.6. It will be IPP 6.1 gold update 2 or 3. I don't know exactly right now and don't know about the date right now. I'll say about date late.
Pavel.
Mikael_Grev
初學者
965 檢視
Hello Mikael!
Pavel.
Thanks Pavel!
Much appreciated.
Micke
oku
初學者
965 檢視
Hello Mikael!
Pavel.
Thank you: finally, these are good news!
Pavel_B_Intel1
965 檢視
Hi All!
the IPP 6.1 gold update 2 without this bug will be soon (1-2 weeks)
Pavel
Artem_V_Intel
員工
965 檢視
The Intel C++ Compiler Professional Edition 11.1 Update 3 for Mac OS X is avalaible now at the Intel Registration Center.
bash-3.2# cat csupport
Package ID: m_cproc_p_11.1.076
This package contains:
Intel C++ Compiler for Mac OS* X version 11.1
Intel Debugger for Mac OS* X version 11.1
Intel Integrated Performance Primitives 6.1 Update 2 for Mac OS* X
Intel Math Kernel Library 10.2 Update 2 for Mac OS* X
Intel Threading Building Blocks 2.2 for Mac OS X, Update 1
For information about how to find Technical Support, Product Updates, User Forums, FAQs, tips and tricks, and other support information, please visit http://www.intel.com/software/products/support/cmac .
Note: If your distributor provides technical support for this product, please contact them for support rather than Intel.
You need a valid license to use this product.bash-3.2#
I checked two examples of unsuccessful linking from posts #8 and #19. Please see the results below.
My configuration:
bash-3.2# icc -V
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20091012 Package ID: m_cproc_p_11.1.076
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
bash-3.2# sw_vers
ProductName: Mac OS X
ProductVersion: 10.6
BuildVersion: 10A432
#8:
bash-3.2# gcc-4.2 -arch x86_64 main.c -I /opt/intel/Compiler/11.1
/076/Frameworks/ipp/include/ -L/opt/intel/Compiler/11.1/076/Frameworks/ipp/lib -lippsemerged -lippsmerged -lippiemerged -lippimerged -lippcore -o ippTest
main.c: In function 'main':
main.c:18: warning: 'ippiResize_8u_C3R' is deprecated (declared at /opt/intel/Compiler/11.1/076/Frameworks/ipp/include/ippi.h:5087)
I added two libraries into original link line. Without this unresolved dependencies error will be obtained.
#19:
bash-3.2# icc -c test.c -o test.o
bash-3.2# echo -e "_myfunc" > lib.script
bash-3.2# libtool -dynamic -arch_only x86_64 -exported_symbols_list ./lib.script test.o -o libmytest.dylib
bash-3.2#
Art
Chao_Y_Intel
主席
965 檢視
Hi Mikael,
This problem has been fixed in IPP 6.1 update 2 release. This package is included in the latest Compiler Professional Edition for Mac OS* X, Version 11.1 Update 3.
Chao
Mikael_Grev
初學者
965 檢視
Quoting - Chao Y (Intel)
Hi Mikael,
Chao
Thank you Chao!
I will try it asap. And upgrade my other computers to Snow Leaoperd. :)
Cheers,
Mikael
回覆
