make_executable
Emre_Y_
I am trying to build IPP 7.1 samples in Ubuntu.
When I run, I get the following error: Unknown CMake command "make_executable"
My kernek (OS) is up-to-date.
 Can you help me how to solve ?
Emre
CMake Error at CMakeLists.txt:68 (make_executable):
Unknown CMake command "make_executable".
CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 2.8)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run "cmake --help-policy CMP0000".
This warning is for project developers. Use -Wno-dev to suppress it.
-- Configuring incomplete, errors occurred!
Chuck_De_Sylva
Emre,
Please refer to this thread on the topic: http://software.intel.com/en-us/forums/topic/339934
- Chuck
