- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I registered as a student and got a license number for Intel® Parallel Studio XE Cluster Edition for Linux and all its subcomponents including IPP
I then tried to download an old version of IPP (5.3) but the installation does not accept the license number I got for parallel studio latest version
What should I do
Mostafa
Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Mostafa,
Thanks for reaching out to us here. I will respond to you soon.
Best,
Bjoern
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Mostafa,
I checked your license and saw that you have a SystemLocked license and you are registered on two systems with two host IDs in total. Your license should work also for older IPP libraries.
How to:
- When you install any older library make sure you are installing the library on the systems with the host IDs you have registered. Other systems will not work.
- Use the license file directly and not the serial number. You will find more information here. I will send you the license file, just in case it got lost.
- Just in case: Intel IPP 5.3 Linux, Update 4 links below
As a registered user, you can also use Intel Premier Support for faster and more private support.
Bjoern
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
