6823 Discussions
problem with ippiDivC_8u_C1RSfs with large images.
santoguya
I'm using ippiDivC_8u_C4RSfs to divide an image by a constant for a 4-channel 8u image, and for certain sizes of images, it does not complete the operation on a certain amount of pixel columns on the right side of the image.
For a 3456X3456 image, it omits 96 columns of pixels on the right side.
For a 4608X4050 image, it omits128 columns of pixels on the right side.
I am pretty sure that I am calling DivC with the correct inputs, because when i use the same format of inputs in an 1-channel 8u image or Divide Two Images (Div_8u_C4RSfs) on a 4-channel 8u image i get the correct results.
Is there a bug with 4-channel 8u divide const on large images?
Ivan_Z_Intel
Thanks for your message!
This bug will be fixed in next version of library.
IZ
santoguya
Ok cool thanks!
When will the next version be available?
Vladimir_Dudnik
The next version of IPP is 6.0 beta. It should be available sometime in Q2'08
Vladimir
