problem with ippiYCbCr422_8u_C2P3R
shyaki
I wanted to convert YUY2 to YUV422, but the color of the image was not correct after calling ippiYCbCr422_8u_C2P3R().
I successfully converted to YUV422 by YUY2 -> YUV420 -> YUV422 for the same data.
It seems to me that ippiYCbCr422_8u_C2P3R() has a bug.
Vladimir_Dudnik
Could you please attach piece of code which does not work as expected?
Vladimir
shyaki
The YUY2 -> YUV422 was not implemented originally in UMC::ColorSpaceConversion, but I added the branch in
ColorSpaceConversion::GetFrame
switch
(srcFormat) {
case YUY2:
switch (dstFormat) {
case
YUV422:
status = ippiYCbCr422_8u_C2P3R(pSrc[0], pSrcStep[0], pDstYVU, pDstStepYVU, srcSize);
break;
After I added the code, I just used the VideoProcessing object to do the conversion:
pYUV422_8bit
->SetAlignment(16);
pYUV422_8bit->Init(width, height, YUV422, 8);
pYUV422_8bit->Alloc();
ret = m_pVideoProcessing->GetFrame(pYUY2_8bit,pYUV422_8bit);
The result was not correct.
But I could do the conversion in two steps like
Vladimir_Dudnik
may be the issue is in the way you call this function, I mean parameters you put into function may not correlate with what function expecting?
This function work quite perfectin IPPJPEG codec (JPEGView sample).
Vladimir
