umc_transcoder problem
gossamer
I have problem with sample application umc_transcoder when using on 9GB .yuv file.
Application is called by following parameters:
umc_transcoder_con -i myfile.yuv -t mymusic.wav -o output.ts -vf_mpeg2_ts
Than, application freeze forever in following procedure call:
pTranscoder->Init(t_params)
I was tracing which call fails in Init procedure and gets right to :
inline
Status Event::Wait(void)
return vm_event_wait(&m_handle);
} // Status Event::Wait(void)
Application use all processor power but looping indefinite in Wait function.
What can cause this behavior ?
.yuv file was created by demuxing mpeg2ts file via simple_player routines.
Sven
Vladimir_Dudnik
Hello Sven,
I've created issue report for you on Intel Premier Support, so you will be notified on that issue investigation results.
Vladimir
gossamer
Thank you!
I've been struggling with that problem for a while, as trying to make h264 downscale routine.
