Intel® MPI Library
Can't install Parallel Studio XE 2015 Update1 on Scientific Linux 6.6
Zhenzhen_B_
When I install Parallel Studio XE 2015 Update1 on Scientific Linux 6.6, the message shows:
Missing optional prerequisites
-- Intel(R) MPI Library, Development Kit 5.0 Update 1 for Linux* OS: Unsupported OS
-- Intel(R) Trace Analyzer and Collector 9.0 Update 1 for Linux* OS: Unsupported OS
-- Intel(R) VTune(TM) Amplifier XE 2015: Unsupported OS
-- Intel(R) Inspector XE 2015: Unsupported OS
-- Intel(R) Advisor XE 2015: Unsupported OS
-- Intel(R) Parallel Studio XE 2015 Composer Edition for C++ Linux*: Unsupported OS
-- Intel(R) Parallel Studio XE 2015 Composer Edition for Fortran Linux*: Unsupported OS
-- Intel(R) Parallel Studio XE 2015 Composer Edition for Fortran and C++ Linux*: Unsupported OS
And when I type a selection [2] to show the detailed info about issue(s), it shows:
Step 1 of 6 | Prerequisites > Missing Optional Prerequisite
Detected operating system is not supported. Supported operating system for this release are:
    - Ubuntu* 12.04 (Intel(R) 64), 14.04 (Intel(R) 64);
    - SUSE Linux Enterprise Server* 11 (Intel(R) 64), 12  (Intel(R) 64);
    - Red Hat Enterprise Linux* 6 (Intel(R) 64), 7  (Intel(R) 64);
    - Fedora* 20 (Intel(R) 64), 21  (Intel(R) 64);
    - Debian* 6.0 (Intel(R) 64), 7.0  (Intel(R) 64);
    - CentOs* 6  (Intel(R) 64);
When I skipped missing optional prerequisites and installed it by default, I could not find "psxevar.sh" in subdirectory "/opt/intel/parallel_studio_xe_2015". I thought I must have lost some critical components of Parallel Studio XE 2015 Update1.
Does it mean that I can not install Parallel Studio XE 2015 Update1 on Scientific Linux 6.6?
While, I was told that Scientific Linux is very similar with Red Hat Enterprise Linux. So how could I install Parallel Studio XE 2015 Update1 on Scientific Linux 6.6?
Thank you very much!
Shaolong_C_
I think you should try the version 2013
我们实验室装的就是2013版的
Gergana_S_Intel
Hi Zhenzhen,
Thanks for getting in touch.  It's true that Scientific Linux is not a supported Operating System distribution but I believe it should work since it's so similar to Red Hat.
You mention that the "psxevar.sh" file was missing after install.  Can you double-check the spelling of the file?  It should be called psxevars.sh.  Here's an example:
[gergana@host1 ~]$ ls /opt/intel/parallel_studio_xe_2015/psxevars.sh
If the psxevars.sh file does not exist, please provide the install log (usually created in /tmp on the node where you started the installation).  That will help us determine what the root cause of the issue might be.
~Gergana
Zhenzhen_B_
Thanks for helping me very much, a teacher helped me and successfully installed Parallel Studio XE 2015 Update1 on Scientific Linux 6.6 at last.
The reason why I failed to install before was that the network connection was instable and I downloaded an incomplete package /(ㄒoㄒ)/~~
Luis_Agustin_N_
Hi! could you be more specific about how do you  it? thanks!
Reza_M_1
hello Guys,
I have same problem installing Parallel Studion, cluster version on Scientific Linux.
i can finish installation but when i run the psxevars.sh nothing will be set in envirounment variables.
After using " which mpirun" command system cannot find any path.
anybody knows what is wrong ?
Zhenzhen_B_
Dear Reza M:
I suppose you should try: ./psxevars.sh ia32 or ./psxevars.sh intel64 instead of ./psxevars.sh
If that still can not help, I suggest you editing your .bash_profile or .bashrc file.
I edit my .bash_profile manually as follows:
# .bash_profile
# Get the aliases and functions
if [ -f ~/.bashrc ]; then
    . ~/.bashrc
fi
# User specific environment and startup programs
source /home/soft/intel/parallel_studio_xe_2015/psxevars.sh ia32
source /home/soft/intel/parallel_studio_xe_2015/psxevars.sh intel64
source /home/soft/intel/impi/5.0.2.044/bin64/mpivars.sh intel64
CPATH=$CPATH:/home/soft/intel/include
export INCLUDE=$INCLUDE:/home/soft/intel/include
export I_MPI_MPD_RSH=ssh
export I_MPI_USE_DYNAMIC_CONNECTIONS=0
export I_MPI_FABRICS_LIST="ofa,dapl,tcp,tmi"
export I_MPI_DEBUG=5
export I_MPI_FALLBACK_DEVICE=1
Hope that can help you!
Regards.
