Intel® MPI Library
2285 Discussions
MPI openmp fopenmp oopenmp qopenmp
jimdempseyatthecove
On Linux, using Eclipse, I am creating a C project that uses a combination of MPI and OpenMP.
I can get the project to build, but with some warning that I can ignore. This may not necessarily be an Intel, but a heads up.
When building the sample "Hello world" as OpenMP only, icc is used, and the build works without warnings.
When building the sample "Hello world" as MPI only, mpicc is used, and the build works without warnings.
When I build a mixed program, using mpicc, I receive warning relating to choice of options for enabling OpenMP. It appears that icc and mpicc are not using the same options.
The following is a successful build, but with warnings:
Building file: ../src/TestCramesOpenMPMPI.c
Invoking: Intel C Compiler
mpicc -g -O0 -I/opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/include -qopenmp -fopenmp -MMD -MP -MF"src/TestCramesOpenMPMPI.d" -MT"src/TestCramesOpenMPMPI.d" -c -o "src/TestCramesOpenMPMPI.o" "../src/TestCramesOpenMPMPI.c"
gcc: unrecognized option '-qopenmp'
Finished building: ../src/TestCramesOpenMPMPI.c
Building target: TestCramesOpenMPMPI
Invoking: Intel C++ Linker
mpicc -shared-intel -qopenmp -L/opt/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64 -fopenmp -o "TestCramesOpenMPMPI"  ./src/TestCramesOpenMPMPI.o
gcc: unrecognized option '-shared-intel'
Finished building target: TestCramesOpenMPMPI
Jim Dempsey
TimP
Intel mpi provides wrappers mpiicc for icc and mpicc for gcc.  So the usual convention that mpicc defaults to gcc is followed.  Some open source mpi require rebuilding mpi against icc to make the switch.
jimdempseyatthecove
Thanks. I will have to consider/experiment with mpiicc.
What threw me off was the build announcement:
Silly of me to assume that meant the Intel C Compiler was going to be used to compile the program...
Jim Dempsey
