Intel® MPI Library
Size of MPI_TAB_UB
John_Y_
In the Intel MPI library reference manual it states that MPI_TAG_UB (under the section Using ILP64 - Known Issues and Limitations)
Predefined commuicator attribugs ... MPI_TAG_UB ... are returned by the functions MPI_GET_ATTR and MPI_COMM_GET_ATTR as 4-byte integers
I've attached a short test case (test.f90) I'm running under 64-bit linux using ifort 16.0.1 and Intel MPI 5.1.2.  When I enable the '-check all' compiler flag (test.sh), the run time checks fail whenever I pass MPI_TAG_UB as a 4-byte integer to the MPI_COMM_GET_ATTR function but pass whenever I pass MPI_TAG_UB as an 8-byte integer.  If I do not enable the '-check all' compiler flag (test_nocheck.sh), then the code seems to run ok for either 4-byte or 8-byte MPI_TAG_UB
Is the manual correct regarding this or are the run-time checks hitting some other issue?
John
Steve_H_Intel1
John,
   You provided two Shell scripts called "test_nocheck.sh1" and "test.sh1". Each Shell script references the driver called "mpif90". The "mpif90" driver uses "gfortran". Error messages of the form:
    f951: error: unrecognized command line option "-i8"
    f951: error: unrecognized command line option "-fpp"
are appearing during compilation.
-Steve
John_Y_
Steve,
I believe this is an issue with your build environment.  In my environment, mpif90 is most definitely calling ifort and not gfortran.  The problem should occur if you change the build script to make sure that the Intel fortran compiler is being used.
John
Steve H. (Intel) wrote:
John,
-Steve
Steve_H_Intel1
John,
   You are incorrect. There is nothing wrong with the build environment. By default for Intel MPI Library, one can simply call "mpiifort" if one wishes to use the Intel Fortran compiler for the various Fortran Programming Language Standards (this assumes that the patron has the Intel Fortran Compiler installed). There are two sets of MPI compilation drivers in the Intel MPI Library ".../bin" directory. The first set of MPI compilation drivers, by default, use the GNU compilers, and the second set of MPI compilation drivers, which begin with the prefix "mpii...", reference the Intel compilers.
Questions:
1) Could you please verify that you have the following MPI compiler drivers in your ".../bin" directory for Intel MPI Library:
      mpicc       mpicxx       mpif77      mpif90       mpifc       mpigcc       mpigxx       mpiicc       mpiicpc       mpiifort
2) For the two scripts that you provided: "test_nocheck.sh1" and "test.sh1", should there be an "mpirun" command at about line 17?
 13 echo
 14 echo "====================="
 15 echo "4-byte mpi interface test, 4 byte system integer, 8-byte ATTRIB "
 16 mpif90 -fpp -check all -DMPI_MPI_INTEGER_TYPE=4 -DMPI_SYS_INTEGER_TYPE=4 test.f90
 17
Thank you,
-Steve
John Y. wrote:
Steve,
John
John_Y_
Steve, It was not my intention to suggest that your build environment was incorrect in any way, but only that it was different than my build environment where mpi90 is calling ifort and not gfortran. The compiler flags are for ifort not gfortran. 1) All the executable you listed are in the Intel MPI bin directory. I believe the the reason mpif90 is calling ifort is because our system administrator has set the environment flag "I_MPI_F90" to ifort. Anyway, I changed the supplied shell scripts to use mpiifort and the same issue as in the original post arises. 2) Thanks, there should be an mpirun statement as suggested. Adding it produces results to support the original post. Thanks, John
Steve_H_Intel1
John,
   For the two scripts "test_nocheck.sh1" and "test.sh1", would you please check my work? The scripts where modified from something like (line numbers are included):
 12 echo
 13 echo "====================="
 14 echo "4-byte mpi interface test, 4 byte system integer, 8-byte ATTRIB "
 15 mpif90 -fpp -DMPI_MPI_INTEGER_TYPE=4 -DMPI_SYS_INTEGER_TYPE=4 test.f90
 16
to:
 12 echo
 16 mpirun -n 1 ./a.out
 17
Does the modified excerpt look proper? Please note that for the "test.sh1" script, the "-check all" command-line option is part of the "mpif90" driver compilation.
Secondly, here is an excerpt of what I am seeing for the "4-byte mpi interface test, 4-byte system integer, 4-byte ATTRIB " test-case via "test.sh1":
echo
echo "4-byte mpi interface test, 4-byte system integer, 4-byte ATTRIB "
mpif90 -fpp -check all -DMPI_MPI_INTEGER_TYPE=4 -DMPI_SYS_INTEGER_TYPE=4 -DFOUR_BYTE_ATTRIB test.f90
mpirun -n 1 ./a.out
The output is:
 mpif90 for the Intel(R) MPI Library 5.1.3 for Linux*
 Copyright(C) 2003-2015, Intel Corporation.  All rights reserved.
 ifort version 16.0.3
     NPROC:            1
     RANK:            1
                        I8B                      I4V            syst_int_kind         MPI_ADDRESS_KIND         kind(attrib_val)
                          8                        4                                 4                                            8                        4
   ATTRIB_VAL:           2147483647
  Boundary Run-Time Check Failure for variable 'test_$ATTRIB_VAL'
  forrtl: error (76): Abort trap signal
  Image              PC                Routine            Line        Source
  a.out              0000000000478575  Unknown               Unknown  Unknown
  a.out              0000000000476197  Unknown               Unknown  Unknown
  a.out              00000000004293B4  Unknown               Unknown  Unknown
  a.out              00000000004291C6  Unknown               Unknown  Unknown
  a.out              0000000000405506  Unknown               Unknown  Unknown
  a.out              0000000000409318  Unknown               Unknown  Unknown
  libpthread.so.0    00000033A460F710  Unknown               Unknown  Unknown
  libc.so.6          00000033A3A32625  Unknown               Unknown  Unknown
  libc.so.6          00000033A3A33E05  Unknown               Unknown  Unknown
  a.out              0000000000478943  Unknown               Unknown  Unknown
  a.out              0000000000403DB4  MAIN__                     64  test.f90
  a.out              000000000040351E  Unknown               Unknown  Unknown
  libc.so.6          00000033A3A1ED5D  Unknown               Unknown  Unknown
  a.out              0000000000403429  Unknown               Unknown  Unknown
  =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
  =   PID 28434 RUNNING AT impic.clusterlab.intel.com
  =   EXIT CODE: 6
  =   CLEANING UP REMAINING PROCESSES
  =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
  =   EXIT CODE: 6
I believe that the key components from the "test.f90" source are:
                 Integer, parameter :: I4B = selected_int_kind(9)   ! 4-byte integer
                 integer, parameter, public :: mpi_int_kind = I4B
                 integer(I4B) :: attrib_val ! Accordint to intel mpi mautal, MPI_TAB_UB attribute always a 4-byte integer ??
                 call MPI_COMM_GET_ATTR(MPI_COMM_WORLD,MPI_TAG_UB,attrib_val,flag,ierr)
where MPI_COMM_GET_ATTR has the prototype:
                 MPI_COMM_GET_ATTR(INTEGER COMM, INTEGER COMM_KEYVAL, INTEGER(KIND=MPI_ADDRESS_KIND) ATTRIBUTE_VAL, LOGICAL FLAG, INTEGER IERROR)
The Fortran parameter MPI_ADDRESS_KIND is defined as:
                  INTEGER MPI_ADDRESS_KIND
                  PARAMETER (MPI_ADDRESS_KIND=8)
I believe that when the "-check all" compilation option is used, the Fortran runtime system is catching a precision mismatch between the variable "attrib_val" and the formal argument to "MPI_COMM_GET_ATTR" which has the data-type attributes "INTEGER(KIND=MPI_ADDRESS_KIND) ATTRIBUTE_VAL". For the script "test.sh1", you are consistently getting the line of output:
for each experiment that completes with the runtime error or completes without the runtime error.
At the URL:
               https://software.intel.com/sites/default/files/managed/be/4e/intel-mpi-5.1.3-developer-reference-linux.pdf
under the section titled, "Using ILP64" and the subsection titled, "Known Issues and Limitations", you pointed out that the manual states: "Predefined communicator attributes MPI_APPNUM, MPI_HOST, MPI_IO, MPI_LASTUSEDCODE, MPI_TAG_UB, MPI_UNIVERSE_SIZE, and MPI_WTIME_IS_GLOBAL are returned by the functions MPI_GET_ATTR and MPI_COMM_GET_ATTR as 4-byte integers."
As you mentioned in your initial inquiry, the script "test_nocheck.sh1" completes without error, and I believe that the manual is correct in regards to the functions MPI_GET_ATTR and MPI_COMM_GET_ATTR returning 4-byte integers. I hope that this information helps.
Thank you,
-Steve
John_Y_
At the URL:
Steve,
1. Your modifications look good.  Thanks for confirming the behavior.
2. As I understand it then, MPI_TAG_UB should be defined as MPI_ADDRESS_KIND which would be an 8-byte integer on a 64-bit system.  So, when the manual says MPI_TAG_UB is "returned by the functions MPI_GET_ATTR and MPI_COMM_GET_ATTR as 4-byte integers" it is only talking about the value and not the data type.
Honestly, I find the manual misleading on this issue because it says 'returned by ... as 4-byte integers'.  To me this is indicating that the data type itself is a 4-byte integer.  I suggest that, if possible, the manual be modified to clarify this point that the actual data type of the values are not necessarily 4-byte integers but just that the maximum value returned is that of a 4-byte integer.
Thanks for all your help. I believe the issue is clear now.
John
