Intel® MPI Library
2288 Discussions
Cisco MDS switch - Cant extract info.
amit09_chopra
There is a CSCO_TPC MDS9000 series switch somewhere in SAN which is visible to my host.
In Device Manager under Computer Management, we see TPC device under category 'OTHER DEVICES'
I need to find the scsi portNo, Bus No, targetID and LUN number for TPC device without using any windows registry functions.
In setup API's, the GUID 'GUID_DEVCLASS_TAPEDRIVE' represents tapes and 'GUID_DEVCLASS_DISKDRIVE' represents physical drives.
Is there a GUID Class corresponding to Cisco Switch (or any TPC Device) ?
Can we not use any other mechanism to find the TPC device?
Even by using the StoragePortClassGuid, I am not able to extract the TPC device info.
The SNIA HBA APIs doesnt list out the device name.
Waiting for suggestions.
Thank you
CSpot
I would recommend you to contact their support department, they will help you out with your problem. Also, if you wish to increase your knowledge and skills, you can gain the CISCO certification and have a job in many reputed companies.
