Intel® MPI Library
2284 Discussions
Collecting OpenMP regions with Intel Trace Collector
Noe-Ohana
I am trying to follow the steps from Intel Trace Collector documentation for collecting data about OpenMP regions.
I must be missing something because the resulting trace does not contain any OpenMP information:
I am working on Windows, with Fortran code. I have Intel Parallel Studio XE 2020 Update 2 Cluster Edition for Windows, and Visual Studio 2017.
Here is how I compile and link the code:
> ifort -Qopenmp -trace -openmp -c test.f90
> Link /OUT:test.exe /LIBPATH:"%VT_ROOT%\dll" /SUBSYSTEM:CONSOLE VT.lib impi.lib test.obj
And here is how I run it:
mpiexec -trace -n 2 -genv OMP_NUM_THREADS=8 -genv INTEL_LIBITTNOTIFY64="%VT_ROOT%\dll\VT.dll" test.exe
Does anyone have any idea what could go wrong?
Labels (2)
AbhishekD_Intel
We tried your code sample and we are also getting the same result with ITAC, so we are forwarding this issue to the concerned team.
Warm Regards,
Abhishek
Kevin_O_Intel1
Can you attach the trace you collected?
Noe-Ohana
Sure, here it is.
Thank you very much for having a look into it.
Kevin_O_Intel1
You should also verify the program is actually running with openmp.
Noe-Ohana
The program is indeed running with OpenMP. I can see it in the code output (Hello world from each thread), and even the collected trace detects 2 processes and 16 threads. It simply does not instrument the OpenMP regions.
Kevin_O_Intel1
Reviewing the result and will see if I can duplicate
Noe-Ohana
Hi.
Do you have any update on this topic?
Kevin_O_Intel1
I will give an update as soon as I can reproduce. Checking
Kevin_O_Intel1
Did you try using the directions documented https://software.intel.com/content/www/us/en/develop/documentation/itc-user-and-reference-guide/top/user-guide/recording-openmp-regions-information.html
Windows* OS
  • Your application should be:
  • linked with the Intel implementation of OpenMP.
  • dynamically linked with the
    VT.dll
     library and Intel MPI Library.
    The example command line to compile the application may look as follows:
    > mpiicc -trace -openmp myapp.c
  • Make sure the
     environment variable contains the full path to the
    VT.dll
     library.
  • Run your application using the
    mpiexec
     command to trace the data.
Noe-Ohana
Thank you for coming back to me.
Those are the directions I have tried to follow.
Do you mean that the issue does not reproduce on your side? Are you doing anything differently?
From the original post:
Kevin_O_Intel1
My results are slightly different ...~75% serial 25% MPI calls 0% OMP
I believe this is because loops might be happening too fast for us to collect any samples... but I will verify with team
Noe-Ohana
All right, thank you very much.
I have tried to profile a real application the same way, and I always get 0s in OpenMP.
Kevin_O_Intel1
Actually, I think you are right... this looks like a bug to me. I am filing a bug report and we will try to fix in a later version.
Thank you very much for reporting the issue.
