I am able to compile a hello_world.c program with mpiicc but am unable to get it to run. It works for me with Intel 2014 - 2018, but not with 2019.5.
Debugging output:
=================================================================================== hjohnson@tuxfast:/tmp/intelmpi-2019$ env I_MPI_DEBUG=6 I_MPI_HYDRA_DEBUG=on mpirun -np 1 ./a.out [mpiexec@tuxfast] Launch arguments: /project/software/intel_psxe/2019_update1/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin//hydra_bstrap_proxy --upstream-host tuxfast --upstream-port 33709 --pgid 0 --launcher ssh --launcher-number 0 --base-path /project/software/intel_psxe/2019_update1/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/ --tree-width 16 --tree-level 1 --time-left -1 --collective-launch 1 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /project/software/intel_psxe/2019_update1/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9 =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 0 PID 30410 RUNNING AT tuxfast = KILLED BY SIGNAL: 4 (Illegal instruction) =================================================================================== hjohnson@tuxfast:/tmp/intelmpi-2019$ env I_MPI_DEBUG=6 I_MPI_HYDRA_DEBUG=on gdb ./a.out ... (gdb) run Starting program: /tmp/intelmpi-2019/a.out [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". Program received signal SIGILL, Illegal instruction. MPL_dbg_pre_init (argc_p=0x0, argv_p=0x0, wtimeNotReady=61440) at ../../../../src/mpl/src/dbg/mpl_dbg.c:722 722 ../../../../src/mpl/src/dbg/mpl_dbg.c: No such file or directory. (gdb) backtrace #0 MPL_dbg_pre_init (argc_p=0x0, argv_p=0x0, wtimeNotReady=61440) at ../../../../src/mpl/src/dbg/mpl_dbg.c:722 #1 0x00001555545850fe in PMPI_Init (argc=0x0, argv=0x0) at ../../src/mpi/init/init.c:225 #2 0x0000000000400ec3 in main () (gdb) quit A debugging session is active.
連結已複製
1 回應
