Intel® MPI Library
Linking MKL_DFTI error
Masrul
Dear all;
I need to use mkl_dfti module. For the following sample code,
program test
    use MKL_DFTI
    Complex :: X(32)
    Real :: Y(34)
    type(DFTI_DESCRIPTOR), POINTER :: My_Desc1_Handle, My_Desc2_Handle
    Integer :: Status
    Status = DftiCreateDescriptor( My_Desc1_Handle, DFTI_SINGLE,&
       DFTI_COMPLEX, 1, 32 )
    Status = DftiCommitDescriptor( My_Desc1_Handle )
    Status = DftiComputeForward( My_Desc1_Handle, X )
    Status = DftiFreeDescriptor(My_Desc1_Handle)
    Status = DftiCreateDescriptor(My_Desc2_Handle, DFTI_SINGLE,&
       DFTI_REAL, 1, 32)
    Status = DftiCommitDescriptor(My_Desc2_Handle)
    Status = DftiComputeForward(My_Desc2_Handle, Y)
    Status = DftiFreeDescriptor(My_Desc2_Handle)
end
I am getting following error;
 error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MKL_DFTI]
use MKL_DFTI
I have checked my environment variables.
echo $MKLROOT
/usr/local/intel-2015.2/composer_xe_2015.2.164/mkl
echo $CPATH
/usr/local/intel-2015.2/composer_xe_2015.2.164/ipp/include:/usr/local/intel-2015.2/composer_xe_2015.2.164/mkl/include:
/usr/local/intel-2015.2/composer_xe_2015.2.164/tbb/include:/usr/local/intel-2015.2/composer_xe_2015.2.164/ipp/include:
/usr/local/intel-2015.2/composer_xe_2015.2.164/mkl/include:/usr/local/intel-2015.2/composer_xe_2015.2.164/tbb/include:
echo $LD_LIBRARY_PATH
/usr/local/intel-2015.2/composer_xe_2015.2.164/compiler/lib/intel64:
/usr/local/intel-2015.2/composer_xe_2015.2.164/mpirt/lib/intel64:
/usr/local/intel-2015.2/composer_xe_2015.2.164/ipp/../compiler/lib/intel64:
/usr/local/intel-2015.2/composer_xe_2015.2.164/ipp/lib/intel64:
/usr/local/intel-2015.2/composer_xe_2015.2.164/ipp/tools/intel64/perfsys:
/usr/local/intel-2015.2/composer_xe_2015.2.164/mkl/lib/intel64:
/usr/local/intel-2015.2/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.1:
/usr/local/intel-2015.2/composer_xe_2015.2.164/debugger/ipt/intel64/lib
I used following command to compile: ifort -mkl test.f90
Please help me to figure out the mistake.
Best Regards
Masrul
Klaus-Dieter_O_Intel
Hi Masrul,
Either use the following command line (in that order of source files) for compilation:
ifort -mkl $MKLROOT/include/mkl_dfti.f90 test.f90
or insert the following statement as first line into your test code:
include "mkl_dfti.f90"
Both will create the module files mkl_dfti_type.mod and mkl_dfti.mod in your working directory.
Best regards
Klaus-Dieter
