- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hi users and developers,
I am having a stringe result come from MPI_Allreduce subroutine in fortran. Here is the thing:
[fortran]
ALLOCATE(mesh%idx%lxyz_inv(nr(1, 1):nr(2, 1), nr(1, 2):nr(2, 2), nr(1, 3):nr(2, 3)))
mesh%idx%lxyz_inv(:,:,:) = 0
!In a subroutine, An array was first allocated and initialized. nr(1, ?):nr(2, ?) are all -36:36 for the test run
npoints = product(nr(2, 1:3) - nr(1, 1:3) + 1)
call MPI_Allreduce(MPI_IN_PLACE, mesh%idx%lxyz_inv(nr(1, 1), nr(1, 2), nr(1, 3)), npoints, MPI_INTEGER, MPI_BOR, mpi_world%comm, mpi_err)
[/fortran]
There were something wrong here at run time (I just ran it by typing a.exe. Not a parallel run). Before MPI_Allreduce, the first 48 elements of mesh%idx%lxyz_inv were all zero. But after the call was made, the first 48 elements of mesh%idx%lxyz_inv became:
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 1140850688 1 0
0 0 0 0 0 32768
64 4194304 64 896 384 0
-2 37010544 0 0 0 0
0 0 0 0 1078984704 0
0 1 0 1 0 3899248
And I noticed that the first strange number 1140850688 is the value of MPI_IN_PLACE defined in mpif.h. Other than that I have completely no clue of it.
I cannot simplify it to a small test program since when I test MPI_Allreduce with the same size array in a simple code, it works fine.
I am using intel Cluster studio 13 with everyting updated and intel MPI. I am trying to compile a 64 bit program so I used the header and libray in $(I_MPI_ROOT)em64t. I don't know whether that's the problem of this strange result. The compile is fine except a lot of "warning LNK4049: locally defined symbol mpifcmb5_ imported", "warning LNK4049: locally defined symbol mpipriv1_ imported", "warning LNK4049: locally defined symbol mpipriv2_ imported" and "warning LNK4049: locally defined symbol mpiprivc_ imported" when linking. OS is win 7 64bit.
Any comment will be appreciated! I can attach my project if it is necessary. Thanks.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
You should not be seeing the linker errors. The easiest way to solve this is if you can send the project. Either attach it to a post, or if you'd prefer, you can send it directly to me.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
James,
Thanks for your response. I sent you a message with my solution attached.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I've got the Visual Studio* solution you sent. What version of Visual Studio* are you using? I'm using 2010, and thus far I'm up to 2 hours waiting for the solution to load. If you have the Intel® Trace Analyzer and Collector, try linking with VTmc.lib. This is the Correctness Checker library, and will verify that the MPI calls are correct. It will slow the application significantly, so I don't recommend using it outside of development. I'll try this myself once I can get the solution loaded. Have you tried this on Linux*?
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi James,
I am using the same version, MSVS 2010. There seems to be a small problem somewhere in the IVF. I post it here:http://software.intel.com/en-us/forums/topic/368495
There is a quick fix by diabling the Database of IVF. Then everything should be fine. Could you please try it again after disabling the Database?
I never used Trace Analyzer. I'll learn to use it. Not sure how far I can go, so I am still hoping that you can help me out.
Yonghui
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
Thank you for the information, that does help load it more quickly. I'll try linking with the Correctness Checker and see if I can find anything.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi James,
Did you see what is the problem in the code? I tried to remove it from the source and test it with single CPU. It turned out to be OK.
Other than that I don't have any new discovery.
Yonghui
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
I have not been able to find anything yet. I'm going to try to get a smaller reproducer together and have our developers look at it.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
OK. Thanks a lot.
I am looking forward for the result.
Yonghui
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
The developers have found and corrected the problem. The fix will be available in our next release.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Great! It was the Fortran wrapper problem or the MPI library problem? Just curious.
Yonghui
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
The problem was due to an incorrectly exported symbol from MPI.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
The newest version of the Intel® MPI Library, Version 4.1 Update 1, is now available for download from the Intel® Registration Center. Please download it and verify that it corrects the problem for you.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi James,
I can't see it in intel Reg Center. All I can see is "intel cluster studio". And I can't see it in intel software manager where I update my software.
Can you give a link to download?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi James,
I just checked it. The problem is fixed! Thanks a lot.
But it seems that there is one more problem that wasn't there before. I am looking into it to see.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Yonghui,
Great! I'm going to go ahead and close the Allreduce issue. Once you know if there is a problem, let me know and we'll look into it.
Sincerely,
James Tullos
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks James.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
