Intel® MPI Library
2274 Discussions
MPI_Init failure on Windows 10
BLH
I'm using MPI 2021.10 on Windows 10 Pro and trying to get the benchmark examples running on a single process, in particular the one in benchmarks\imb\WINDOWS\IMB-MPI1_VS_2017.  I am using VS2019 though but the project upgraded fine.
I'm getting a failure in MPI_Init:
C:\PF(x86)\Intel\oAPI\m\2021.10.0\benchmarks\i\W\I-M1_V_2017\x64\Debug> IMB-MPI1.exe
Abort(1090959) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init_thread: Other MPI error, error stack:
MPIR_Init_thread(176)........:
MPID_Init(1548)..............:
MPIDI_OFI_mpi_init_hook(1554):
(unknown)(): Other MPI error
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1090959
system msg for write_line failure : No error
The call stack is this:
> impi.dll!MPIR_Err_return_comm() Unknown
impi.dll!PMPI_Init_thread() Unknown
IMB-MPI1.exe!main(int argc, char * * argv) Line 296 C++
IMB-MPI1.exe!invoke_main() Line 79 C++
IMB-MPI1.exe!__scrt_common_main_seh() Line 288 C++
IMB-MPI1.exe!__scrt_common_main() Line 331 C++
IMB-MPI1.exe!mainCRTStartup(void * __formal) Line 17 C++
kernel32.dll!BaseThreadInitThunk() Unknown
ntdll.dll!RtlUserThreadStart() Unknown
Any ideas?  I'm stuck.
ShivaniK_Intel
"Can you confirm which files in the installation that we are allowed to redistribute with our commercial product?"
As stated in the license in $I_MPI_ROOT/licensing/license.txt, you may use and redistribute the software, which is provided in binary form only, without modification, provided the conditions in the license are met.
If this resolves your issue could you please let us know whether we can go ahead and close this issue?
Thanks & Regards
Shivani
BLH
I think we found the problem.  We were testing in a Windows command prompt, not the Intel oneAPI Command Prompt which sets up a different environment.
We finally got this to work in a Windows command prompt by copying a few more files from the MPI installation to the same location as our executable.
Specifically:
libfabric/bin/libfabric.dll
bin/release/impi.dll
libfabric/bin/utils/fi_info.exe
libfabric/bin/utils/fi_pingpong.exe
I'm assuming we can redistribute these.
ShivaniK_Intel
Thanks for posting in the Intel forums.
We have tried to replicate the issue at our end but we are able to run the IMB benchmark successfully at our end. Please refer to the below attachment for the output details.
OS: Windows 11
To investigate more regarding the issue could you please provide us with the below details?
1. cpuinfo
2. visual studio version
Thanks & Regards
Shivani
BLH
Hi Shivani,
I wrote on 10/24/2023 that we solved our technical issue.
-Ben
ShivaniK_Intel
>>>"I wrote on 10/24/2023 that we solved our technical issue."
Sorry for the inconvenience. I missed your second post, so responded back we are unable to replicate the issue.
Regarding this, we will get back to you.
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
