Intel® MPI Library
2273 토론
MPI applications hangs with a limided number of processes
thierrybraconnier
초급자
16,696 조회수
I am working on a MPI application which hangs when it is launched with more than 2071 MPI processes. I have succeeded to make a small reproducer of this:
program main
use mpi
integer :: ierr,rank
call mpi_init(ierr)
call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
if (rank.eq.0) print *,'Start'
call test_func(ierr)
if (ierr.ne.0) call exit(ierr)
call mpi_finalize(ierr)
if (rank.eq.0) print *,'Stop'
contains
subroutine test_func(ierr)
integer, intent(out) :: ierr
real :: send,recv
integer :: i,j,status(MPI_STATUS_SIZE),mpi_rank,mpi_size,ires
character(len=10) :: procname
real(kind=8) :: t1,t2
ierr=0
call mpi_comm_size(MPI_COMM_WORLD,mpi_size,ierr)
call mpi_comm_rank(MPI_COMM_WORLD,mpi_rank,ierr)
call mpi_get_processor_name(procname, ires, ierr)
call mpi_barrier(MPI_COMM_WORLD,ierr)
t1 = mpi_wtime()
do j=0,mpi_size-1
  if (mpi_rank.eq.j) then
    do i=0,mpi_size-1
       if (i.eq.j) cycle
      call MPI_RECV(recv,1,MPI_REAL,i,0,MPI_COMM_WORLD,status,ierr)
      if (ierr.ne.0) return
      if (i.eq.mpi_size-1) print *,'Rank ',j,procname,' done'
    enddo
  else
    call MPI_SEND(send,1,MPI_REAL,j,0,MPI_COMM_WORLD,ierr)
  endif
enddo
t2 = mpi_wtime()
if (mpi_rank.eq.0) print*,"time send/recv = ",t2-t1
end subroutine test_func
end program main
When I run this program with less than 2071 MPI processes then it works but when I run it with more than 2072 processes then it hangs as if there are deadlock on the send/recv.
The outputs running the programm with I_MPI_DEBUG=5 are
[0] MPI startup(): Intel(R) MPI Library, Version 2019 Update 9 Build 20200923 (id: abd58e492)
[0] MPI startup(): Copyright (C) 2003-2020 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.10.1-impi
[0] MPI startup(): libfabric provider: verbs;ofi_rxm
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 48487 r30i0n0 {0,24}
[0] MPI startup(): 2070 34737 r30i4n14 {18,19,20,42,43,44}
[0] MPI startup(): I_MPI_CC=icc
[0] MPI startup(): I_MPI_CXX=icpc
[0] MPI startup(): I_MPI_FC=ifort
[0] MPI startup(): I_MPI_F90=ifort
[0] MPI startup(): I_MPI_F77=ifort
[0] MPI startup(): I_MPI_ROOT=/data_local/sw/intel/RHEL7/compilers_and_libraries_2020.4.304/linux/mpi
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_RMK=lsf
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_EXTRA_FILESYSTEM=1
[0] MPI startup(): I_MPI_EXTRA_FILESYSTEM_FORCE=lustre
[0] MPI startup(): I_MPI_DEBUG=5
Question 1 : Is there a reason explaining this behavior?
Notice that if I change the send/recv communication pattern by either a bcast one
do j=0,mpi_size-1
    call MPI_BCAST(send,1,MPI_REAL,j,MPI_COMM_WORLD,ierr)
  else
    call MPI_BCAST(recv,1,MPI_REAL,j,MPI_COMM_WORLD,ierr)
  endif
enddo
or an allgather one
call MPI_ALLGATHER(MPI_IN_PLACE,0,MPI_DATATYPE_NULL,recv,1,MPI_REAL,MPI_COMM_WORLD,ierr)
print *,'Rank ',mpi_rank,procname,' done '
then the programm runs (faster of course) but with up to 4000 MPI processes (I did not try with more MPI processes). Unfortunatly, I can not change the communication send/recv pattern in the original application with either the bcast or the allgather ones.
Question 2 : When I run the original application with 2064 MPI processes (86 nodes having 24 cores), the consummed memory for MPI buffers is around 60 GB per node and with 1032 MPI processes (43 nodes having 24 cores) it is around 30 GB per node. Is there a way (environment variables...) to reduce this amount of consummed memory?
Many thanks in advance for your help
Thierry
레이블 (2)
0 포인트
1 솔루션
James_T_Intel
중재자
15,675 조회수
I apologize for the delayed response. I have tested this on 2019 Update 9 (the version of Intel® MPI Library included in Intel® Parallel Studio XE 2020 Update 4) and on 2021.3. The error appears in 2019 Update 9 and is resolved and works as expected in 2021.3. Please update your version of Intel® MPI Library to resolve this issue.
If you are unsure of how to upgrade, we have transitioned from Intel® Parallel Studio XE to Intel® oneAPI. Specifically, the Intel® MPI Library is part of Intel® oneAPI HPC Toolkit. Please go to https://software.intel.com/content/www/us/en/develop/tools/oneapi.html#gs.c2n2h8 for overview information about Intel® oneAPI and https://software.intel.com/content/www/us/en/develop/tools/oneapi/hpc-toolkit.html#gs.c2n2xn for information on how to download Intel® oneAPI HPC Toolkit.
As this is resolved with the latest version, I am proceeding with closing this thread for Intel support. Any further posts on this thread will be considered community only.
원본 게시물의 솔루션 보기
0 포인트
13 응답
SantoshY_Intel
중재자
16,679 조회수
Could you please keep the flags -check_mpi and I_MPI_DEBUG=10 to the command you used to run the code and share with us the complete error log?
Also, can you provide the result for the below command?
ulimit -a
Thanks & Regards,
Santosh
0 포인트
thierrybraconnier
초급자
16,668 조회수
Hello Santosh,
Here are the results of the ulimit -a command
Frontale node :
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 1545489
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) 30000000
open files (-n) 32768
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 4096
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
compute node :
core file size (blocks, -c) unlimited
pending signals (-i) 513931
max memory size (kbytes, -m) unlimited
stack size (kbytes, -s) 300000
The log ans err files with the -check_mpi flag ans I_MPI_DEBUG=10 for np=2071 (which works) and np=2072 (which hangs) are given as attched files.
Thierry
0 포인트
thierrybraconnier
초급자
16,616 조회수
Hello Santosh,
Frontale node :
compute node :
Thierry
0 포인트
SantoshY_Intel
중재자
16,602 조회수
We see that -check_mpi flag isn't worked for you. Follow the below steps to make use of -check_mpi flag.
source <installation path of parallel Studio> /itac/20XX.XX/bin/itacvars.sh
 or
source <installation path of parallel studio>/ psxevars.sh
Now check cluster checker version by using the below command:
clck --version
If you see the version details, Now try running the program as below example:
I_MPI_DEBUG=10 mpirun -check_mpi -np <total No. of processes> -ppn <No. of processes per node ./a.out
Also, share with us the complete log.
Thanks & Regards,
Santosh
0 포인트
thierrybraconnier
초급자
16,583 조회수
Hello Santosh,
Thnaks for your answer.
Regarding parallel studio, it is not insatlled on my cluster but itac is and I have source the itacvars.sh script and launched the command
I_MPI_DEBUG=10 mpirun -check_mpi -np <total No. of processes> -ppn <No. of processes per node ./a.out.
I have got 3 differents behaviors according with the numbers of mpi process running
  1. every thing is running fine (see test_np532.out and test_np532.err attached files)
  2. the run hangs but some of the send/recv exchanges are completed (see test_np535.out and test_np535.err)
  3. the run hangs and no send/recv exchanges are completed (see test_np540.out and test_np540.err)
Notice that
  • test_npXXX.xxx is the log and err files for np=XXX
  • problem seems to occur for less MPI processes: I guess it is because "itac" slows down the runs
Thierry
0 포인트
SantoshY_Intel
중재자
16,526 조회수
Thanks for providing the logs. We are working on your issue and we will get back to you soon.
Thanks & Regards,
Santosh
0 포인트
James_T_Intel
중재자
16,519 조회수
Do you see the same behavior on the current version, 2021.2? What hardware are you using?
0 포인트
thierrybraconnier
초급자
16,274 조회수
Hello James,
The most recent compiler I have access on the cluster is intel-compxe/19.1.3.304 and the most recent MPI library is intel-mpi/2020U4.
Here are some information about the hardware I am using:
uname -a
Linux r29i3n17 3.10.0-957.el7.x86_64 #1 SMP Thu Oct 4 20:48:51 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 48
On-line CPU(s) list: 0-47
Thread(s) per core: 2
Core(s) per socket: 12
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 63
Model name: Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz
Stepping: 2
CPU MHz: 2900.238
CPU max MHz: 3300.0000
CPU min MHz: 1200.0000
BogoMIPS: 5000.18
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 30720K
NUMA node0 CPU(s): 0-11,24-35
NUMA node1 CPU(s): 12-23,36-47
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm epb intel_ppin ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm xsaveopt cqm_llc cqm_occup_llc dtherm ida arat pln pts spec_ctrl intel_stibp flush_l1d
Thierry
0 포인트
thierrybraconnier
초급자
16,132 조회수
Hello James,
uname -a
lscpu
CPU(s): 48
Socket(s): 2
NUMA node(s): 2
CPU family: 6
Model: 63
Stepping: 2
CPU MHz: 2900.238
BogoMIPS: 5000.18
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 30720K
Thierry
0 포인트
thierrybraconnier
초급자
16,048 조회수
Hello James,
command uname -a
command lscpu
CPU(s): 48
Socket(s): 2
NUMA node(s): 2
CPU family: 6
Model: 63
Stepping: 2
CPU MHz: 2900.238
BogoMIPS: 5000.18
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 30720K
command ibstat
CA 'mlx5_0'
CA type: MT4115
Number of ports: 1
Firmware version: 12.27.1016
Hardware version: 0
Node GUID: 0xb88303ffff8292fc
System image GUID: 0xb88303ffff8292fc
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 5281
LMC: 0
SM lid: 1
Capability mask: 0x2659e848
Port GUID: 0xb88303ffff8292fc
Link layer: InfiniBand
Do not hesitate to contact me if you need more info (just give me the command to get them).
Thierry
0 포인트
thierrybraconnier
초급자
15,882 조회수
Hello James,
Since I have got no answer from you for more than one month, I am coming back to you.
If you need more informations, please, send me the commands for obtaining them and I will send them to you.
Thierry
0 포인트
James_T_Intel
중재자
15,676 조회수
0 포인트
thierrybraconnier
초급자
15,390 조회수
Hello James,
Many thanks for your answer, your help ans your time spent on the issue.
Thierry
0 포인트
응답
