Intel® MPI Library
2287 Discussions
Not able to run intel mpi(2021.11 v and higher) in cluster setup on windows
vivagr
I'm facing an issue when i run the mpi lib in cluster setup with multiple processes running on different machine on windows platform.
Machine#1:
-host <hostname1> -n 1 -map W:\\<hostname1>\D$ -wdir <workDir> -path <pathDir> <process exe> <args>
Note: W: is mapped for D drive of machine#1
Machine#2
-host <hostname2> -n 1 -map W:\\<hostname1>\D$ -wdir <workDir> -path <pathDir> <process exe>  <customFlag> W:\\<AccessSharedDirOfMachine#1> <other args>
mpi process running on Macine#2 tries to access shared access dir of Machine#1. but result in error Access denied. However from machine#2, the shared dir is accessible through window-run command.
This was running fine with older mpi version 2021.8 or prior.
Can anyone from Intel team  look into it?
Vivek
