Intel® MPI Library
2288 Discussions
"Hello world" not running on MPI 2021.14
tuhh1996
Hi all,
im pretty new to this forum - so I might ask some stupid questions.
In the past, I have used the intel compiler a lot on my machine. But due to an update to opensuse leap 15.6, I have recently installed the newest intel one api, including the mpi version 2021.14. As always,  I tried to compile and run a simple "hello world" program first. It failed with
MPIR_Init_thread(193)........:
MPID_Init(1715)..............:
MPIDI_OFI_mpi_init_hook(1673):
create_vni_context(2258).....: OFI EP enable failed (ofi_init.c:2258:create_vni_context:Cannot allocate memory)
cnl7408@fds071:~/calc/testing> mpirun --version
Intel(R) MPI Library for Linux* OS, Version 2021.14 Build 20241121 (id: e7829d6)
Copyright 2003-2024, Intel Corporation.
 The program is
PROGRAM hello_world_mpi
include 'mpif.h'
integer process_Rank, size_Of_Cluster, ierror, tag
call MPI_INIT(ierror)
call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
print *, 'Hello World from process: ', process_Rank, 'of ', size_Of_Cluster
call MPI_FINALIZE(ierror)
END PROGRAM
I compiled and executed the code with
mpiifx test_mpi.f90
mpirun -n 2 ./a.out
A few month ago, on the same system (Opensuse Leap 15.4, and older intel mpi version) the programm was working ...
Does someone has an idea what could cause an issue here?
Cheers,
Malte
TobiasK
@tuhh1996 please provide more information about your HW/SW environment. Please provide the output of I_MPI_DEBUG=10 and I_MPI_HYDRA_DEBUG=1
tuhh1996
Hi TobiasK,
the issue is already resolved - I had to define the variable I_MPI_FABRICS="shm".
Thanks anyway,
Malte
