Intel® MPI Library
2275 讨论
Per-rank timing heterogeneity in MPI_File_Write_at_all
4f0drlp7eyj3
初学者
1,809 次查看
Hi, I ran a timing test for 16 ranks writing 500 MB each from a single Skylake node to a Lustre PFS. Simple C test code (which I can provide), built with Intel 2020.1.217. What I see is Rank 1 has diff 1.749272 Rank 8 has diff 1.764557 Rank 11 has diff 1.777109 Rank 4 has diff 1.782356 Rank 6 has diff 1.833384 Rank 15 has diff 1.858618 Rank 0 has diff 3.101054 Rank 10 has diff 4.237715 Rank 12 has diff 4.288582 Rank 7 has diff 4.291451 Rank 3 has diff 4.295812 Rank 14 has diff 4.302241 Rank 5 has diff 4.339086 Rank 13 has diff 5.141735 Rank 9 has diff 5.141858 Rank 2 has diff 5.209390 With another MPI implementation, I see Rank 0 has diff 7.493546 Rank 10 has diff 7.493548 Rank 13 has diff 7.493549 Rank 14 has diff 7.493545 Rank 15 has diff 7.493545 Rank 1 has diff 7.493545 Rank 2 has diff 7.493544 Rank 3 has diff 7.493544 Rank 4 has diff 7.493544 Rank 5 has diff 7.493546 Rank 6 has diff 7.493545 Rank 7 has diff 7.493546 Rank 8 has diff 7.493552 Rank 9 has diff 7.493545 Rank 11 has diff 7.493548 Rank 12 has diff 7.493545 My question is, why is Intel's timing so heterogeneous? The two implementations clearly are using different algorithms, but Intel looks like it's getting better timings somehow (through buffering, scheduling, ?). Thanks; Chris
0 项奖励
4 回复数
4f0drlp7eyj3
初学者
1,805 次查看
Sorry, hate this board. Let's try for better formatting.
Thanks; Chris
0 项奖励
SantoshY_Intel
主持人
1,771 次查看
>>" I ran a timing test for 16 ranks writing 500 MB each from a single Skylake node to a Lustre PFS. Simple C test code (which I can provide), built with Intel 2020.1.217."
-- Can you please share a sample reproducer code?
Thanks & Regards,
Santosh
0 项奖励
SantoshY_Intel
主持人
1,700 次查看
Could you please provide the above-requested details (Sample reproducer code)?
Thanks & Regards,
Santosh
0 项奖励
SantoshY_Intel
主持人
1,558 次查看
As we have worked with you internally and upon request, we are closing this thread.
Thanks & Regards,
Santosh
0 项奖励
回复
