Intel® MPI Library
2275 Discussions
Sending, receiving result in deadlock
anishtain4
I'm trying to solve a simple problem with MPI but when I comment all the PRINT lines the program gets into a deadlock, when I uncomment one of them then the programm proceeds smoothly!!!! I can't understand what is wrong with this? I'm using blocking send and receive so time difference that print makes should not has any effect on the overal performance!
The idea of IF is that odd processes first send and evens recieve then vice versa, so there should not be any deadlock even if there don't be any buffer on the way!
What is wrong with my algorithm that makes it break?
[bash] integer,parameter   ::IM=100,JM=100
 REAL,ALLOCATABLE  ::T(:,:),TF(:,:)
  CALL MPI_COMM_RANK(MPI_COMM_WORLD,RNK,IERR)
  CALL MPI_COMM_SIZE(MPI_COMM_WORLD,SIZ,IERR)
 prv = rnk-1
 nxt = rnk+1
 LIM = INT(IM/SIZ)
 IF (rnk==0) THEN
     ALLOCATE(TF(IM,JM))
     prv = MPI_PROC_NULL
 ELSEIF(rnk==siz-1) THEN
     NXT = MPI_PROC_NULL
     LIM = LIM+MOD(IM,SIZ)
 END IF
 ALLOCATE(T(LIM+2,JM+2))
 IF (MOD(RNK,2)==0) THEN
         CALL MPI_SEND(T(2,:),JM+2,MPI_REAL,PRV,10,MPI_COMM_WORLD,IERR)
         !PRINT*,RNK,'SENT'
         CALL MPI_RECV(T(1,:),JM+2,MPI_REAL,PRV,20,MPI_COMM_WORLD,STAT,IERR)
         !PRINT*,RNK,'RECIEVED'
     ELSE
         CALL MPI_RECV(T(LIM+2,:),JM+2,MPI_REAL,NXT,10,MPI_COMM_WORLD,STAT,IERR)
        CALL MPI_SEND(T(LIM+1,:),JM+2,MPI_REAL,NXT,20,MPI_COMM_WORLD,IERR)
         !PRINT*,RNK,'SENT'
     END IF [/bash]
Dmitry_K_Intel2
Hi Anishtain,
Your code (a bit modified) below works fine for number of processes from 2 to 16 on Intel64.
Do you define all variables? SIZ may be a real variable.
implicit none
include 'mpif.h'
integer,parameter :: IM=100,JM=100
REAL,ALLOCATABLE :: T(:,:),TF(:,:)
integer RNK,IERR,SIZ, prv, nxt, LIM
integer STAT(MPI_STATUS_SIZE)
CALL MPI_INIT(IERR)
prv = rnk-1
nxt = rnk+1
LIM = INT(IM/SIZ)
IF (rnk==0) THEN
ALLOCATE(TF(IM,JM))
prv = MPI_PROC_NULL
NXT = MPI_PROC_NULL
END IF
!PRINT*,RNK,'SENT'
ELSE
!PRINT*,RNK,'SENT'
END IF
IF (rnk==0) DEALLOCATE(TF)
DEALLOCATE(T)
call MPI_FINALIZE(IERR)
print *, rnk, " - done"
END PROGRAM
Regards!
Dmitry
anishtain4
Thanks Dmitry, the problem was with the optimization as I found by someone's advice. I just added the -O0 and it works. siz was integer btw.
