Intel® MPI Library
2275 Discussions
Two nodes linpack test error!
liuzhaoqiang
The following is my error reporting information. Please help me!!
Thanks!
I've configured ssh-free login and set up nfs file system, using Intel oneapi.
And the firewall is turned off.
CPU:2*E5 2620 v4 per node;1Gb Ethernet;OS:Ubuntu20.04.6-live-server.amd64.iso
My guess is that it's a compatibility issue, who can tell me the real reason!
AishwaryaCV_Intel
Thank you for reaching out to the Intel communities.
Could you please provide us Intel oneAPI version you are using?
I am successfully able to run the linpack test with FI_PROVIDER= mlx Can find the attached screenshot of linpack test in linpack_text1.png and linpack_test2.png
Could you please check and let us know the FI_PROVIDER you are using?
To find and check for provider can follow the link:
https://www.intel.com/content/www/us/en/developer/articles/technical/mpi-library-2019-over-libfabric.html
Thanks And Regards,
Aishwarya
liuzhaoqiang
Hi  Aishwarya,
     Thank you for answer me.
     I'm using Intel oneapi version is '2022.3.1'.
    I'm using FI_PROVIDER=tcp;ofi_rxm
Thanks!
AishwaryaCV_Intel
Thanks for providing the requested information.
<<< My guess is that it's a compatibility issue, who can tell me the real reason!
Could you please elaborate on this statement you mentioned? What exactly you meant by compatibility issue?
Thanks And Regards,
Aishwarya
liuzhaoqiang
I'm sorry that my description may have misunderstood you. This is just my own guess, because the cpu I use is already very old, but intel OneAPI is very new, so I have this idea.
AishwaryaCV_Intel
Thanks for the clarification.
Could you please upgrade to the 2023 version of Intel oneAPI and try running the basic IMB benchmark using the below provided command , without specifying any other environment flags.
mpirun -np 4 -ppn 2 IMB-MPI1
Please let us know if you are able to run successfully.
Thanks And Regards,
Aishwarya
AishwaryaCV_Intel
We haven't heard back from you, Could you please let us know if you are able to run basic IMB benchmark successfully by upgrading to 2023 as mentioned above?.
Thanks & Regards,
Aishwarya
AishwaryaCV_Intel
We have not heard back from you. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Aishwarya
