Intel® MPI Library
2284 Discussions
[feature request] mpi_f08 in ilp64 mode
foxtran
New Contributor III
Merry Christmas everyone!
Is there any plan to add mpi_f08 for ILP64 mode?
Currently, the following code can not be compiled:
program main
  use mpi_f08
  implicit none
  integer, parameter :: is = 8
  integer(is) :: ierror
  call mpi_init(ierror)
  call mpi_finalize(ierror)
end program main
With the following command:
mpiifx test_mpi_ILP64.f90 -ilp64
 It fails as:
test_mpi_ILP64.f90(6): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MPI_INIT]
test_mpi_ILP64.f90(7): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MPI_FINALIZE]
compilation aborted for test_mpi_ILP64.f90 (code 1)
I'm using the following ifx from the corresponding oneAPI (so, the resulting binaries looks ok, when they are compiled):
$ ifx --version
ifx (IFX) 2023.2.0 20230622
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
Igor
TobiasK
@foxtran
Please note, for the time being we will not support ILP64 mode in MPI_F08.
However, we might reconsider this decision if more customers will request this feature.
RabiyaSK_Intel
We have informed the concerned development team. We will get back to you soon.
Thanks & Regards,
Shaik Rabiya
TobiasK
@foxtran
currently we do not support ILP64 in our MPI_F08 module. For large counts we advise to use MPI 4.0 standard 'large counts' which is available in MPI_F08.
However, I am collecting customer requests for ILP64 support in MPI_F08, if there is a critical mass we may reconsider supporting ILP64.
Why do you want to use ILP64 instead of large counts with MPI_F08?
Best
Tobias
TobiasK
@foxtran
