Intel® MPI Library
how can i active mpdboot on my each nodes
Sungho_L_1
My cluster is rocks plus cluster, centos 6.3, 12cores 32nodes....
I can ssh to each nodes without passward
I've installed intel cluster studio on my nfs directory=> /exports/apps/intel
Then I tried to type "source /export/apps/intel/icsxe/2013.0.028/ictvars.sh intel64"
It was working well
I created a ~engeo/.mpd.conf and chmod 600 .mpd.conf
Then I typed "cat > .mpd.hosts"
node01
node16
ctrl + D
Finally I tpyed
I got error which you can check what I've attached
Give me any advice plz...
Thanks in advance
Sungho Lee
Sungho_L_1
it is missed above "I typeed "mpdboot -n 16 -f mpd.hosts""
TimP
Did you move the mpd.py from the directory where you installed it (did you change installation directory as indicated in the message?)
If it's there, do you have execute permissions as required?
Gergana_S_Intel
Hi Sungho,
Thanks for getting in touch. Before we get started, let me say that we're moving away from using the mpds and recommend that customers start switching over to the new Hydra process manager.  It has several benefits, one of which is removing the dependency on starting and closing an mpd ring.
Having said that, an easy test you can do is:
[engeo@earthsimulator ~] ssh node01 ls /export/apps/intel/impi/4.1.0.024/
This will check if that directory path is present on node01 which seems to be the root cause of the error you provided.
~Gergana
