Intel® MPI Library
mpi_abort does not terminate all processes under torque
Bernie_B_
We are running the Nasa Overflow code on a large linux cluster and have found that if the code calls MPI_ABORT it does not terminate as
expected.  We are running version 4.1.027 of Intel MPI.  We running under the Torque resource manager.
Bernie
Bernd_Doser
We have the same problem using IntelMPI 4.1.0.024. MPI_Abort hang until a newline is send.
Bernd
Sebastian_G_
We have the same issue with PBS as job scheduler and mpi version 5.0.3.048.
So the code sends an MPI_ABORT and the processes are not killed correctly that the job hangs in the queue.
Is there a solution to this problem?
Sebastian
