[shell]$ mpiifort foo.F90and likewise with mpiicc:
[: 478: no: unexpected operator
$[/shell]
[shell]$ mpiicc -c foo.cand with mpiicpc:
[: 382: no: unexpected operator
$[/shell]
[shell]$ mpiicpc -c foo.cThis is on Intel64 (i.e. x86_64) Ubuntu 9.10, which has this annoying problem that libstdc++5 is missing, but I fixed that.
[: 389: no: unexpected operator
$[/shell]
In all scripts (mpiifort / mpiicc / mpiicpc) the offending bit of code seems to be this:
[shell]if [ $_force_rel_version == "yes" ]; thenFor reference,
if [ $MPILIBNAME != "mpi_log" ]; then
# Forse linking with release version of the MPI library
MPILIBNAME="mpi"
fi
fi
[/shell]
[shell]$ uname -aAnd:
Linux monostatos 2.6.31-16-generic #53-Ubuntu SMP Tue Dec 8 04:02:15 UTC 2009 x86_64 GNU/Linux
[/shell]
[shell]$ mpiifort --versionHmm. Any ideas?
ifort (IFORT) 11.1 20091012
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
$ mpiicc --version
icc (ICC) 11.1 20091012
$ mpiicpc --version
icpc (ICC) 11.1 20091012
[/shell]
Peter
I must have messed up something on the install.
I did the install with the -no-rpm flag, since otherwise, rpm complained with this error:
[shell]rpm: please use alien to install rpm packages on Debian, if you are really sure use --force-debian switch. See README.Debian for more details.[/shell]
Hi Peter,
I would like to preface this by saying that the Intel MPI Library does not currently support Ubuntu or other Debian-based systems.
Can you tell me which version of the Intel MPI Library you're using? I suspect the latest one (3.2 Update 2) but you can make sure by viewing the contents of the mpisupport.txt file located in the install directory.
Also, does this happen if you just run the standalone compiler (e.g. icc, ifort) outside the mpiicc and mpiifort scripts? Just trying to isolate the problem - it's either the Intel MPI Library scripts, or the underlying compiler.
If you suspect corruption during installation, then uninstalling and running the install scripts again is pretty easy. There should be a uninstall.sh file located in the Intel MPI Library install directory. Speaking of, did you simply run the install script on your problemless system? We posted a short HowTo on installing the Cluster Tools on Debian, but we advise using alien. It'll be interesting to know if you've succeeded in a different way.
Let me know how it goes.
~Gergana
Understood. My real compute cluster uses CentOS 4, but I find it a pain to administer so I use Ubuntu for everything else since it's usually brain-dead easy for people who aren't linux experts like myself :) Thanks so much for offering to help.
Can you tell me which version of the Intel MPI Library you're using? I suspect the latest one (3.2 Update 2) but you can make sure by viewing the contents of the mpisupport.txt file located in the install directory. (etc etc)
Package ID: l_mpi_p_3.2.2.006
Compilers (icc/icpc/ifort) work just fine. Problem seems isolated to scripts. Here's another one, this time with mpirun:
[plain]$ mpirun -np 4 ./gypc
/opt/intel/impi/3.2.2.006/bin64/mpirun: 63: Syntax error: "(" unexpected (expecting "fi")
$ [/plain]
uninstall.sh does not work. Out of the box, it's not executable, but even doing chmod still have problems:
[plain]$ chmod +x uninstall.sh
$ sudo ./uninstall.sh
[sudo] password for pwilliam:
ERROR: File "./impi.uninstall.config" does not exist.
$ [/plain]
I don't remember how I did the install on the Ubuntu 9.04 -> 9.10 system where IntelMPI/mpirun/mpiifort etc work. It was four months ago or so. Sorry. Good question, since I am almost certain that it worked right out of the box, without any tweaking.
I already found your notes at: http://software.intel.com/en-us/articles/installing-cluster-tools-on-debian/
Thanks very much.
Note however that the --extract option does not seem to work:
[plain]$ mkdir myrpmsHowever, it's probably a moot point, since I have the rpm's already (I'm guessing distro changed to include rpms in tar file):
$ sudo ./install.sh --extract=./myrpms/
Extracting components...
Which one of the following would you like?
1. Install cluster node software on an automounted shared file system
2. Install cluster node software on every node of your cluster
x. Exit
Please type a selection (1/2/x) [1]: 1
Illegal option -- extract
[/plain]
[plain]$ ls rpmI'll follow the remainder of your notes on that page. My only question is whether I need to do an install (with dpkg, e.g.) of the runtime component as well. I'm a bit confused that there's an -rt- version and a non-rt version of each rpm. I don't know what that means.
intel-mpi-em64t-3.2.2p-006.x86_64.rpm intel-mpi-ipf-3.2.2p-006.ia64.rpm intel-mpi-rt-ia32-3.2.2p-006.i486.rpm
intel-mpi-ia32-3.2.2p-006.i486.rpm intel-mpi-rt-em64t-3.2.2p-006.x86_64.rpm intel-mpi-rt-ipf-3.2.2p-006.ia64.rpm
[/plain]
Peter
P.S. note this install's not actually on a cluster. It's on a single SMP machine that I use for code development, before I try build/run on the big machine. Not that that makes any difference.....
alien generated an error BTW but then seemed to chug along fine and created a .deb nonetheless:
[plain]$ sudo alien --scripts intel-mpi-em64t-3.2.2p-006.x86_64.rpm
error: incorrect format: unknown tag
intel-mpi-em64t_3.2.2p-7_amd64.deb generated
$[/plain]
I did not try an uninstall, but doing the dpkg should have written over the old install. In fact can verify that this is a new install just doing ls -l to get the modification date:
[plain]$ ls -l `which mpiifort`i.e. the mod date is six minutes ago, when I did the install using dpkg (my clock now says 13:27).
-rwxr-xr-x 1 root root 20345 2009-12-16 13:21 /opt/intel/impi/3.2.2.006/bin64/mpiifort
$[/plain]
However, problem remains:
[plain]$ mpiifort -c painout.F90That might not be so bad, but this is:
$ [/plain]
[plain]$ mpirun ./gypcIt's possible the gzipped tar was corrupted, although it seems unlikely that corruption would have led to such a subtle error. So I think I'll try installing an earlier release and let you know how that works.
$ [/plain]
If that fails, my plan is to go home (the functional computer is my home computer), copy everthing in the mpi directory onto a USB drive, and then copy it over to the non-functional system, since they have identical OS's and hardware. (should work, right?)
Peter
Hi Peter,
To reply to your first post:
I guess you figured it out but the -rt- version contains the runtimes only. The other RPM should extract to the full Intel MPI Library kit, so you can just use that one. We provide the runtime RPM so those can be redistributed by vendors.
As far as your second install, I'm starting to lean towards some sort of corruption of the scripts during install. It seems like it's unable to parse the code itself:
$ [/plain]
You have Python, a Python XML module, and an XML parser installed on this machine, correct?
I don't know if you want to keep playing with it, but I would recommend tossing everything and starting from scratch:
- Remove the existing Intel MPI directory by doing
"$ rm -rf /opt/intel/impi/3.2.2.006"
- Re-download the tar package (it doesn't hurt to try anew) by logging into the Intel Registration Center
- Untar, then go into the rpm/ dir, create the .deb file, and try the install again
If it compains at some point about the Intel MPI Library prefix being taken, go ahead and remove a file called intel_sdp_products.db
. It should be located in the root home directory, under intel/.
On my side, I'll see if I can get access to an Ubuntu machine here, and try the install as well.
Feel free to call me, if you can't access the package from the Intel Registration Center, or have questions.
~Gergana
Thanks so much for your help!!!!!
Problem solved.
I tried installing old versions, tinkering with this and that.... I learned the hard way that you can't undo packages by just doing an "rm -rf" on the whole directory tree (how do packages work? oh well). Ok several hours blown. But....
What finally worked - going from the hint that the scripts weren't being parsed right - is that I just hand-edited the scripts (mpirun, mpiifort, mpicc, etc etc) to use bash instead of sh:
Change:
#!/bin/sh
to:
#!/bin/bash
...on first line of each script.
This worked and seems to have fixed the problem entirely. I am now able to compile and run with mpirun -n 8 (say) my code, just fine!
Thanks again,
Peter
Ah, the joys of computers :)
I'm glad you have it working, Peter. I wonder if doing a symlink from /bin/sh to /bin/bash would have worked as well? But then you'll be overwriting sh
on your system so maybe not ...
Have fun and let us know if you hit other problems.
~Gergana
Hope somebody else finds the info useful. Not sure why sh failed to parse where bash succeeded. Perhaps the fault lies on my end. I'd be curious if any other Ubuntu 9.10 / Intel MPI users find the same problem, or if mine was an isolated incident.
Hi Peter,
I was recently able to get access to a local Ubuntu 9.10 system and ran the installer for the Intel MPI Library. Unsurprisingly, I ran into the same issue as you have:
gsslavov@backuppc:~$ mpirun -np 4 hostname
/home/gsslavov/intel/impi/3.2.2.006/bin/mpirun: 63: Syntax error: "(" unexpected (expecting "fi")
So I did some more digging and this is what I found out:
gsslavov@backuppc:~/intel/impi/3.2.2.006$ ls -l /bin/sh
lrwxrwxrwx 1 root root 4 2009-11-22 03:55 /bin/sh -> dash
It seems that with version 9.10, Ubuntu has decided to change the default shell from bash
to dash
. More info is available from the link in the excerpt below:
In Ubuntu 6.10, the default system shell,
/bin/sh
, was changed todash
(the Debian Almquist Shell); previously it had beenbash
(the GNU Bourne-Again Shell). This document explains this change and what you should do if you encounter problems.
The default login shell remainsbash
As it so happens, the two shells are not fully compatible (since bash
is quite more extensive than dash
), thus leading to the errors you and I are seeing.
This is actually a fairly easy fix on your side. Simply, you need to change the /bin/sh
symlink to point from dash
to bash
$ rm /bin/sh
$ ln -s /bin/bash /bin/sh
This seems to be an acceptable solution based on the Ubuntu article.
I hope this helps. I'll also update the knowledge base article I wrote to include this information.
Happy Holidays,
~Gergana
I am trying to use the Intel MPI for linux on a debian system Ubuntu 10.04, my cpu is running on 32-bit.
ifort, icc etc all work fine. I am using the non-commercial version for the intel compilers.
I downloaded the latest version (4.0.3.008) of the Intel MPI library and untarred it...
In the rpm folder i used 'alien --scripts' to create this file 'intel-mpi-ia32_4.0.3p-9_i386.deb'
An error was shown first: error: incorrect format: unknown tag
Then i used 'dpkg --intsall intel-mpi-ia32_4.0.3p-9_i386.deb'
Selecting previously deselected package intel-mpi-ia32.
(Reading database ... 161071 files and directories currently installed.)
Unpacking intel-mpi-ia32 (from intel-mpi-ia32_4.0.3p-9_i386.deb) ...
Setting up intel-mpi-ia32 (4.0.3p-9) ...
I tried to use mpiifort
mpiifort: command not found
I have no idea what the problem is, hope you can provide some advice
Shawn
source /opt/intel/impi/4.0.3/bin/mpivars.sh
Intel software install policies require that no MPI path is set up by default, so that it will be possible to select the MPI of your choice by adding it to your paths. You could do that e.g. in .bashrc if that fits your needs.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
