Is it possible to enable part of cores only?
sysprogerz
If i have 4 cpu, each 8 cores. Can i make it only run 6 core each??
i tried to google but only find limitted info about this and not so clear.
jimdempseyatthecove
Are you using Windows or Linux?
For a specific application or all applications?
For all applications except ....?
With code embedded into the application or external to the application?
For any 6 cores of 8 core processor or a specific set of 6 cores of 8 core processor?
Both Windows and Linux have a mens to control the applicaiton (also known as a process) to a specific hardware thread or set of hardware threads. Where the documentation usually refers to these as "processor". The key words to google are:
affinityprocess restrict
or
affinity programming site:wikipedia.org
The above searches should yield some useful links.
Jim Dempsey
