intel ipp 7.0
joshpriya
i want to write a cryptography program using intel ipp version 7.0 for linux.But after installation process complete ,our system doesnot support the cryptography header file (ippcp.h).i need a help to get out of this problem...kindly send me suggestion for it...
Ibrahim_Umar
Have you obtained the IPP crytography libraries? If not then you will have to make a separate request for it since it is not included in the IPP installer.
Take a look at this page: http://software.intel.com/en-us/articles/download-ipp-cryptography-libraries/
Gennady_F_Intel
That's right. The standart IPP package doesn't contain IPP Crypto package. Crypto libraryavailable as separate installation package.
Two important notes:
1)You must first install the Intel IPP library before installing the IPP cryptography add-on library.
and
2) The version of Crypto package you have to insatll must be the same as version of IPP installed.
for example:
if you have IPP version ( see \doc\ippsupport.txt file )
Package ID: w_ipp_ia32_p_6.1.5.054
then IPP Crypto version must have be the same *_6.1.5.054
--Gennady
shashisinha
Check if the following link is of any help:
Shashi Sinha
