Pls Help: VF Multithread
wisperless
I am a beginner of VF multithread programming. Can anyone give me a sample code how to parallel calculating the summation of 100 numbers, such as one part for the summation from 1 to 50,the other from51 to 100? Thank you :)
Calculating the summation of 100 numbers from 1 to 100
VF sequential code:
integer sum
sum=0
do i=1, 100
sum=sum+i
enddo
TimP
Assuming you are using a Fortran compiler which supports OpenMP, you should find the material at www.openmp.org useful.
