Reader-writer Lock
matt_j
I've written a simple reader-writer lock for my own needs and am just after another pair of eyes to identify any issues I may have missed.
The domain this will be used in involves the vast majority being reads with the workload between each read-request being quite significant (ie., there will be little thread-contention)
A few things to note that may or may not be obvious:
#1: A basic lock needs to be aquired for any request (read/write)
#2: Writers are given priority, the "Writers" variable is about pending-writers, not current writers.
[cpp]struct RWLock
	// Attributes
	Byte Writers;
	Byte Lock;
	Byte Readers;
	Byte Unused;
	// Methods
	Void FASTCALL AquireWrite();
	Void FASTCALL AquireRead();
	Void FASTCALL ReleaseWrite();
	Void FASTCALL ReleaseRead();
NAKED Void FASTCALL RWLock::AquireWrite()
	__asm
		// Signal readers to wait.
		add byte ptr [ecx], 1
		// Aquire lock, no readers.
		mov edx, 1
		ALIGN 16
		SPIN:
			xor eax, eax
			pause
			lock cmpxchg word ptr [ecx+1], dx
			jnz short SPIN
		// Decrement writer-pending count.
		sub byte ptr [ecx], 1
		// Aquired.
		ret
NAKED Void FASTCALL RWLock::AquireRead()
	__asm
		// Aquire lock.
		mov edx, 1
		ALIGN 16
		SPIN:
			xor eax, eax
			pause
			lock cmpxchg word ptr [ecx], dx
			jnz short SPIN
		// Increment reader count.
		lock add byte ptr [ecx+2], 1
		// Free lock.
		mov byte ptr [ecx+1], 0
		// Aquired.
		ret
FORCEINLINE Void FASTCALL RWLock::ReleaseRead()
	// Decrement reader count.
	this->Readers--;
FORCEINLINE Void FASTCALL RWLock::ReleaseWrite()
	// Free lock.
	this->Lock = 0;
}[/cpp]
For C-style ('this' omitted for clarity)
[cpp]/*
 * AquireWrite()
Writers++;
// Aquire lock when no writers or readers are present.
while(Lock != 0 && Readers != 0);
Lock=1;
Writers--;
 * AquireRead()
// Aquire lock when no writers are either present or pending.
while(Writers != 0 && Lock != 0);
Lock=1;
Readers++;
// Free lock
Lock=0;
[/cpp]
Cheers,
Matt.
Dmitry_Vyukov
Valued Contributor I
Quoting - matt.j
[cpp]NAKED Void FASTCALL RWLock::AquireRead()
__asm
// Aquire lock.
mov edx, 1
ALIGN 16
SPIN:
xor eax, eax
pause
[/cpp]
Doesn't it have to be lock cmpxchg word ptr [ecx + 1], dx?
Dmitry_Vyukov
You must use the same address and the same operand size in all atomic RMW operations.
Intel 64 and IA-32 Architectures Software Developer's Manual Volume
3A: System Programming Guide, Part 1
7.1.2.2 Software Controlled Bus Locking
Software should access semaphores (shared memory used for signalling
between multiple processors) using identical addresses *and operand lengths*.
For example, if one processor accesses a semaphore using a word access, other
processors should not access the semaphore using a byte access.
Dmitry_Vyukov
You better align your mutex variable on 4-byte boundary. If it happens to cross cache line boundary it will run very slowly on Intel QPI based system, system-wide quiescence is *very* unpleasant thing.
Dmitry_Vyukov
Quoting - matt.j
[cpp]NAKED Void FASTCALL RWLock::AquireWrite()
__asm
mov edx, 1
ALIGN 16
SPIN:
xor eax, eax
pause
jnz short SPIN
// Aquired.
ret
[/cpp]
Here is a race on [ecx], you use non-atomic operations 'add byte ptr [ecx]' and 'sub byte ptr [ecx]'. Two concurrent writer can damage [ecx], so that it will never become zero again.
Dmitry_Vyukov
Quoting - matt.j
[cpp]
this->Readers--;
[/cpp]
ReleaseReed() is not atomic wrt 'Readers', you need to use 'lock sub' in ReleaseRead(). Otherwise concurrent readers will corrupt 'Readers'.
Chris_M__Thomasson
Quoting - matt.j
Read this whole thread:
Also, here is the best FIFO rw-spinlock out there:
http://groups.google.com/group/comp.programming.threads/browse_frm/thread/be3871ad661efa73/ac0c61ee539625de
I modified it to block, however you can easily change it back to a spinlock if you simply remove the eventcount logic and add a backoff/yield in the wait loops.
Any thoughts?
