SpinWaitLock
racker
I have implemented a simple spinlock based on the intrinsic InterlockedCompareExchange.
The waiting thread loops for some time. After a while it gives up and waits on a condition variable until the lock becomes free again.
I believe to code is correct, as long as everything is executed in the order defined by the code.
Still it happens that a thread is sleeping forever, while the lock is free and sleeping is 1.
It appears that sleeping is incremented _after_ the waiting thread sleeps. I just don't get it.
Any hints are appreciated.
Ralph
[cpp]static volatile unsigned long spinlock;
static volatile unsigned long sleeping;
lock()
{ while(_InterlockedCompareExchange(&spinlock, 1, 0))
{ nloops++;
if(nloops > threshold)
{ pthread_mutex_lock(&mutex);
sleeping++;
pthread_cond_wait(&cond, &mutex);
sleeping--;
pthread_mutex_unlock(&mutex);
break;
unlock()
{ spinlock=0;
if(sleeping)
pthread_cond_signal(&cond);
}[/cpp]
Dmitry_Vyukov
Valued Contributor I
You need #StoreLoad style memory fence in critical store-load sequence. You have basically an instance of Dekker/Peterson algorithm in your slow-path:
http://en.wikipedia.org/wiki/Peterson%27s_algorithm
It won't work without StoreLoad memory fence.
In order to fix you need to insert:
lock()
sleeping++;
_mm_mfence();
unlock()
spinlock=0;
_mm_mfence();
if(sleeping)
Dmitry_Vyukov
lock()
sleeping++;
_mm_mfence();
unlock()
spinlock=0;
_mm_mfence();
if(sleeping)
