Vectorizing 3D Arrays Product in Fortran
Ricardo_F_
Considering the product of arrays with size nx*ny*nz in Fortran. The given cases will generate the same result:
#1
do k=1,nz
 do j=1,ny
  do i=1,nx
   A(i,j,k)=A(i,j,k)*B(i,j,k)*0.5
  enddo
 enddo
enddo
#2
do ijk=1,nx*ny*nz
 A(ijk,1,1)=A(ijk,1,1)*B(ijk,1,1)*0.5
enddo
#3
A(:,:,:)=A(:,:,:)*B(:,:,:)*0.5
#4
A=A*B*0.5
Question: which case (#1, #2, #3 or #4) is the best in terms of vectorization and performance and why?
Someone recommend a literature or website where I can learn more about it?
Thank you,
Ricardo
jimdempseyatthecove
#4 "should" be best and equivalent to #1
To improve performance you would want to align the arrays (A and B) to cache line address
!DIR$ ATTRIBUTES ALIGN: 64:: A, B
#2 won't work if array bounds checking is enabled. If array dimensions for aligned allocations do not produce rows (1st index) of multiples of cache line, for the example above #1 can have the loops collapsed (see IVF index)
Jim Dempsey
TimP
At full optimization, ifort would perform an optimization equivalent to #2 if possible.  #3 is prone to generation of temporary arrays.  ifort optimization reports should show when either of those happen.
jimdempseyatthecove
FWIW I use a similar technique to #2. In a module I have:
    subroutine ArrayDivide6x6(a,d)
        implicit none
        real(i8), intent(inout) :: a(6*6)
        real(i8), intent(in) :: d
        a = a / d
    end subroutine ArrayDivide6x6
REAL(i8),DIMENSION(6,6), INTENT(OUT) :: qq_Transpose
call ArrayDivide6x6(qq_Transpose, exp(xsi*z))
You should be able to use a similar technique with your example code.
YMMV
I noticed in IVF V17u1 an optimization issue with
  qq_Transpose = qq_Transpose / exp(xsi*z)
Jim Dempsey
