Writing assembly code for IA64
ayushgupta
Hi All,
I am new to IA64.
I wanted to know how to write a code in assembly for IA64 in which i need to do the following:
Call a C function from this code.
While using ml64.exe (that comes with WDK 6000)for x64, i could use .extern.
But ias.exe (that comes with WDK) for IA64 does not treat .extern as a valid token.
Any help is appreciated.
Ayush Gupta
muhzulfikar
Hi Ayush Gupta
I will give you some tutorial for writing assembly code for IA64
you can open : http://www.gelato.unsw.edu.au/archives/linux-ia64/0604/18019.html
Muhammad Zulfikar
http://zulfikars.org
