Intel® Moderncode for Parallel Architectures
Support for developing parallel programming applications on Intel® Architecture.
linking with two versions of mkl (multi threaded and single threaded) in one application
Michal_K_2
Is it possible to use both the single threaded version of mkl library and the multi threaded version of mkl in one application?
I need the single threaded version to use with PLASMA library, yet at some other part of my code, I need use mkl PARDISO, for which I need the multi threaded version.
Any help will be greatly appreciated.
Cheers
Michal
Michal_K_2
I forgot to say that my operating system is Linux, debian wheezy.
Michal_K_2
I was able to fix the problem, by lining PLASMA with the multi threaded mkl. The crucial thing was to set
call kmp_set_defaults("KMP_AFFINITY=disabled")
which makes PLASMA with multi threaded mkl only 2% slower than PLASMA with single threaded mkl. Without this option it is 3 times slower.
It means that I do not need to link to the single threaded library anymore.
jimdempseyatthecove
If each is establishing its own thread pool, then experiment with KMP_BLOCKTIME environment variable settings or KMP_SET_BLOCKTIME function.
Jim Dempsey
