hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® Moderncode for Parallel Architectures
Support for developing parallel programming applications on Intel® Architecture.
nested loop vectorization in OpenMP taskloop
eric_p_
Principiante
2.736 Vistas
Hi everybody,
I have a simple program with a four nested loop, the outer loop is parallelized with OpenMP taskloop directive and I tried to vectorized the innermost loop.
program main
use modf
use omp_lib
implicit none
integer :: n,i,j,k
integer :: d1,d2,d3,d4
double precision :: corr
double precision :: time
d1 = 100
d2 = 100
d3 = 100
d4 = 40
corr = 2.3
!$omp parallel
!$omp master
allocate(matrix(d1,d2,d3,d4))
allocate(matout(d1,d2,d3,d4))
matrix(:,:,:,:) = 0.0
time = omp_get_wtime()
!$omp taskloop default(none) firstprivate(d1,d2,d3,d4,corr) shared(matrix,matout)
DO n=1,d4
    DO i=1,d3
        DO j=1,d2
            !$omp simd aligned(matrix,matout:64)
            DO k=1,d1
                matout(k,j,i,n) = arraycomp(matrix(k,j,i,n),corr)
            ENDDO
            !$omp end simd
        ENDDO
    ENDDO
ENDDO
!$omp end taskloop
time = omp_get_wtime() - time
!$omp end master
!$omp end parallel
print*,time
end program main
where arraycomp function is contained in module :
module modf
double precision,allocatable,dimension(:,:,:,:) :: matrix
double precision,allocatable,dimension(:,:,:,:) :: matout
contains
function arraycomp(in1,in2) result(output)
    !$omp declare simd(arraycomp)
    double precision, intent(inout) :: in1,in2
    double precision:: output
    output = (in1 + abs(in2))
end function arraycomp
end module
and the code is compiled with this Makefile ( ifort 17.0.1 ) :
test.xx : *.f90
		ifort -O3 -g -xAVX -qopenmp -qopt-report5 -align array64byte $^ -o $@
My problem is that the compiler don't have succes to vectorize the innermost loop  and in optr file is reported this error:
LOOP BEGIN at main.f90(28,7)
   remark #15541: outer loop was not auto-vectorized: consider using SIMD directive
   LOOP BEGIN at main.f90(31,5)
      remark #15521: loop was not vectorized: loop control variable was not identified. Explicitly compute the iteration count before executing the loop or try using canonical loop form from OpenMP specification
      LOOP BEGIN at main.f90(32,9)
         LOOP BEGIN at main.f90(34,19)
         LOOP END
      LOOP END
   LOOP END
LOOP END
Probably this kind of error is due to a runtime assegnation in the task of loop variable.
But there are a way to avoid this behaviour and vectorize correctly the innermost loop?
Thanks for attention
Best regards
Eric
0 kudos
5 Respuestas
McCalpinJohn
Colaborador Distinguido III
2.736 Vistas
The OpenMP standard has a lot of restrictions on what is allowed in a loop targeted by a SIMD pragma.  One restriction that might be relevant here is that the loop cannot contain any branches to outside the loop.  I would guess that the function call is considered to be a branch
Manually inlining the "arraycomp" function should enable vectorization.
eric_p_
Principiante
2.736 Vistas
Thanks for your reply. You're right  with manual inlining the loop was vectorized :
 LOOP BEGIN at main.f90(35,13)
            remark #15388: vectorization support: reference at (36:17) has aligned access   [ main.f90(36,17) ]
            remark #15389: vectorization support: reference at (36:36) has unaligned access   [ main.f90(36,36) ]
            remark #15381: vectorization support: unaligned access used inside loop body
            remark #15305: vectorization support: vector length 4
            remark #15399: vectorization support: unroll factor set to 4
            remark #15309: vectorization support: normalized vectorization overhead 0.364
            remark #15301: OpenMP SIMD LOOP WAS VECTORIZED
            remark #15442: entire loop may be executed in remainder
            remark #15449: unmasked aligned unit stride stores: 1
            remark #15450: unmasked unaligned unit stride loads: 1
            remark #15475: --- begin vector cost summary ---
            remark #15476: scalar cost: 10
            remark #15477: vector cost: 2.750
            remark #15478: estimated potential speedup: 3.230
            remark #15488: --- end vector cost summary ---
LOOP END
but I think that the behavoiur is due to taskloop and not to OpenMP simd, because if I use openmp  do instead openmp taskloop the code was perfectly vectorized:
            remark #15389: vectorization support: reference matrix_(k,j,i,n) has unaligned access   [ main.f90(36,45) ]
            remark #15389: vectorization support: reference matout_(k,j,i,n) has unaligned access   [ main.f90(36,17) ]
            remark #15305: vectorization support: vector length 2
            remark #15309: vectorization support: normalized vectorization overhead 0.052
            remark #15451: unmasked unaligned unit stride stores: 2
            remark #15476: scalar cost: 124
            remark #15477: vector cost: 70.000
            remark #15478: estimated potential speedup: 1.750
            remark #15484: vector function calls: 1
            remark #15489: --- begin vector function matching report ---
            remark #15490: Function call: ARRAYCOMP with simdlen=2, actual parameter types: (vector,uniform)   [ main.f90(36,35) ]
            remark #15492: A suitable vector variant was found (out of 2) with xmm, simdlen=2, unmasked, formal parameter types: (vector,vector)
            remark #15493: --- end vector function matching report ---
         LOOP END
Naturally I prefer the first approach because the speedup his higher!
Thanks again
Eric
jimdempseyatthecove
2.736 Vistas
In your modf, you have not attributed the arrays as being aligned. Therefore the allocation will not (required to) be aligned.
!dir$ attributes align: 64:: matrix
!dir$ attributes align: 64:: matout
Then specify the function as a vector function
!dir$ attributes vector :: arraycomp
Or target a specific processor architecture
!dir$ attributes vector : processor(core_4th_gen_avx) :: arraycomp
!... !dir$ attributes vector : processor(mic_avx512 ) :: arraycomp
Then remove the !$omp simd/end simd
Note, your inner loop k (the one able to vectorize) is .NOT. an OpenMP sliceable DO loop index. Ergo, !$omp simd of this loop index variable is nonsensical.
Jim Dempsey
eric_p_
Principiante
2.736 Vistas
Hi Jim, thanks you to your reply.
I edit the modf.f90 following your suggestion and I try to add the directive to force inlinig:
module modf
contains
!DEC$ ATTRIBUTES FORCEINLINE :: arraycomp
end module
but the loop in main.f is not vectorized. The only way seem the manual inlining or put the function into main program with contains
program main
use modf
use omp_lib
implicit none
integer :: n,i,j,k
d1 = 100
d2 = 100
d3 = 100
d4 = 40
corr = 2.3
!$omp parallel
!$omp master
DO n=1,d4
    DO i=1,d3
        DO j=1,d2
            DO k=1,d1
            ENDDO
        ENDDO
    ENDDO
ENDDO
!$omp end taskloop
!$omp end master
!$omp end parallel
print*,time !,matout(5,5,5,5)
contains
end program main
Reding this two article in Intel site:
https://software.intel.com/en-us/articles/fortran-array-data-and-arguments-and-vectorization
https://software.intel.com/en-us/articles/data-alignment-to-assist-vectorization
seems the only way to align one array declared in one module and allocated in one other is use the flag compiler: -align array64byte
From the example, I understand that it is possible to indicate to compiler that can be vectorize a  loop that work on module array with the directive  !dir$ vector aligned but with the taskloop it is incompatible because the ifort return error due to I must use taskloop in a master session:
main.f90(35): error #7631: This statement or directive is not permitted within the body of an OpenMP* MASTER/END MASTER
block.
compilation aborted for main.f90 (code 1)
Eric
jimdempseyatthecove
2.736 Vistas
Note, when the arrays matrix and matout are aligned allocated, this only assures the compiler that the entire array lowest cell is aligned. IOW only when all indexes of the arrays are a lbound that it is assured to be aligned. Thus for any slicing up of the array (parallel constructs), the compiler cannot know the starting point is aligned.
If you pass a multi-dimensioned array into a parallel region, you might be able to get the loop to vectorize if you can successfully get the collapse to work:
!$OMP TASKLOOP COLLAPSE(4) ...
Though I think you would have better luck using:
!$OMP PARALLEL DO COLLAPSE(4) SCHEDULE(STATIC,SIMD) ...
Jim Dempsey
Responder
