openmp code : less processor than the available
vahid_a_1
Dear All,
I am running my Fortran 90 code in super-computing facility of our university. The max. available processor is 21, however my code is only uses 5 of them. I am using export_OMP_NUM_THREADS=20 however I dont define the stacksize after the compilation.
Would you please let me know what should I investigate to understand the problem? The below information shows that the max. number of available threads are 21 and my code only used 5 of them.
Resource usage summary:
    CPU time :                                   2471026.00 sec.
    Max Memory :                                 351 MB
    Average Memory :                             74.98 MB
    Total Requested Memory :                     2560.00 MB
    Delta Memory :                               2209.00 MB
    Max Processes :                              5
    Max Threads :                                21
jimdempseyatthecove
Your system administrator may have control over limiting the maximum number of threads any one process can use.
And for any one process the OMP_NUM_THREADS can be constricted by OMP_MAX_THREADS.
The report (my guess) indicates you may be running an MPI job with 5 processes (ranks), each process/rank using 21 threads. (5 * 21 threads in use).
TimP do you have any comments on this?
Jim Dempsey
vahid_a_1
Dear Jim, This is an openmp code not the MPI. I guess there should be difference. The administrator tells me that I can use 20 with openmp code. However as I mentioned the code only uses 5 as the report shows. The job file that I use to submit my code is:
#BSUB -J pfm
#BSUB -o pfm.o%J
#BSUB -e pfm.e%J
#BSUB -n 20
#BSUB -R "span[ptile=20]"
#BSUB -M 128
#BSUB -R 'rusage[mem=128]'
#BSUB -W 96:00
#BSUB -L /bin/bash
#BSUB -u
#### queue : ada
module load intel/2015A
ifort -openmp -o a.out huh014_thienBC.f90
export OMP_NUM_THREADS=20
export FORT_FMT_RECL=215
./a.out
Jim Dempsey
jimdempseyatthecove
What does the following show?
CHARACER(LEN=100) :: VAL
!$OMP PARALLEL
WRITE(*,*) OMP_GET_THEAD_NUM()
!$OMP END PARALLEL
WRITE(*,*) "max threads", OMP_GET_MAX_THREADS()
WRITE(*,*) "num procs", OMP_GET_NUM_PROCS()
CALL GET_ENVIRONMENT_VARIABLE("OMP_THREAD_LIMIT",VAL)
WRITE(*,*) "OMP_THREAD_LIMIT",VAL
CALL GET_ENVIRONMENT_VARIABLE("KMP_ALL_THREADS",VAL)
WRITE(*,*) "KMP_ALL_THREADS",VAL
Jim Dempsey
vahid_a_1
The answer is:
max threads                    1
num procs                       20
OMP_THREAD_LIMIT      'blank'
KMP_ALL_THREADS       'blank'
!$OMP PARALLEL
!$OMP END PARALLEL
Jim Dempsey
jimdempseyatthecove
I made a few edits.
Before running, set the environment variable
KMP_SETTINGS=true
This will display the OpenMP related environment variables prior to start of the main program.
Program
program NumThreads
    use omp_lib
    implicit none
    CHARACTER(LEN=100) :: VAL
    !$OMP PARALLEL
    !$OMP MASTER
    WRITE(*,*) "num threads",OMP_GET_NUM_THREADS()
    !$OMP END MASTER
    !$OMP BARRIER
    WRITE(*,*) OMP_GET_THREAD_NUM()
    !$OMP END PARALLEL
end program NumThreads
Results on my system
User settings:
   KMP_SETTINGS=true
Effective settings:
   KMP_ABORT_DELAY=0
   KMP_ABORT_IF_NO_IRML=false
   KMP_ADAPTIVE_LOCK_PROPS='1,1024'
   KMP_ALIGN_ALLOC=64
   KMP_ALL_THREADPRIVATE=128
   KMP_ALL_THREADS=32768
   KMP_ASAT_DEC=1
   KMP_ASAT_FAVOR=0
   KMP_ASAT_INC=4
   KMP_ASAT_INTERVAL=5
   KMP_ASAT_TRIGGER=5000
   KMP_ATOMIC_MODE=1
   KMP_BLOCKTIME=200
   KMP_CPUINFO_FILE: value is not defined
   KMP_DETERMINISTIC_REDUCTION=false
   KMP_DUPLICATE_LIB_OK=false
   KMP_FORCE_REDUCTION: value is not defined
   KMP_FOREIGN_THREADS_THREADPRIVATE=true
   KMP_FORKJOIN_BARRIER='2,2'
   KMP_FORKJOIN_BARRIER_PATTERN='linear,linear'
   KMP_FORKJOIN_FRAMES=true
   KMP_FORKJOIN_FRAMES_MODE=3
   KMP_GTID_MODE=2
   KMP_HANDLE_SIGNALS=false
   KMP_HOT_TEAMS_MAX_LEVEL=1
   KMP_HOT_TEAMS_MODE=0
   KMP_INIT_AT_FORK=true
   KMP_INIT_WAIT=2048
   KMP_ITT_PREPARE_DELAY=0
   KMP_LIBRARY=throughput
   KMP_LOCK_KIND=queuing
   KMP_MALLOC_POOL_INCR=1M
   KMP_MONITOR_STACKSIZE: value is not defined
   KMP_NEXT_WAIT=1024
   KMP_NUM_LOCKS_IN_BLOCK=1
   KMP_PLAIN_BARRIER='2,2'
   KMP_PLAIN_BARRIER_PATTERN='linear,linear'
   KMP_REDUCTION_BARRIER='1,1'
   KMP_REDUCTION_BARRIER_PATTERN='hyper,hyper'
   KMP_SCHEDULE='static,balanced;guided,iterative'
   KMP_SETTINGS=true
   KMP_STACKOFFSET=64
   KMP_STACKPAD=0
   KMP_STACKSIZE=2M
   KMP_STORAGE_MAP=false
   KMP_TASKING=2
   KMP_TASK_STEALING_CONSTRAINT=1
   KMP_USE_IRML=false
   KMP_VERSION=false
   KMP_WARNINGS=true
   OMP_CANCELLATION=false
   OMP_DISPLAY_ENV=false
   OMP_DYNAMIC=false
   OMP_MAX_ACTIVE_LEVELS=2147483647
   OMP_NESTED=false
   OMP_NUM_THREADS: value is not defined
   OMP_PLACES: value is not defined
   OMP_PROC_BIND='false'
   OMP_SCHEDULE='static'
   OMP_STACKSIZE=2M
   OMP_THREAD_LIMIT=32768
   OMP_WAIT_POLICY=PASSIVE
   KMP_AFFINITY='noverbose,warnings,respect,granularity=core,duplicates,none'
 num threads           8
           0
           6
           2
           7
           1
           3
           4
           5
 max threads           8
 num procs           8
 OMP_THREAD_LIMIT
 KMP_ALL_THREADS
Press any key to continue . . .
Jim Dempsey
