Intel® NUCs
Support for Intel® NUC products
12730 Discussions
Driver support assist Sorry, something went wrong while trying to scan.
c1
DSA gives the following message when i scan
i am running windows 10 home upgraded from windows 7
BUILD 21H1
Processor Intel(R) Core(TM) i5-2540M CPU @ 2.60GHz 2.60 GHz
Installed RAM 6.00 GB (5.90 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
AlHill
Use Firefox, Chrome, or Edge only.
Clear the browser cache.
c1
Thanks for the prompt response
Tried this plus install and uninstall makes no differance
AlHill
What anti-virus are you running?  If not Windows Defender, try it with Windows Defender.
c1
am running mcafee turned it off and used defender no differance
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
c1
Thanks stupid question do you want the third party logs as well
c1
Find attached intel ssu report
Alberto_R_Intel
c1, Thank you for posting in the Intel® Communities Support.
For this scenario, we recommend scanning with different browsers. The ones that are supported by Intel® DSA are: Chrome, Firefox and Edge.
Then you can also try to clear the browser cache and then rescan the Intel® DSA tool again.
Also, click “Refresh Results” on the menu on the left-hand side of the Intel® DSA scan page (this acts as a complete “start over” for the service). Reboot the system. (in case the “Refresh page” isn’t enough of a “start over”)
If the problem persists, run the Intel® Driver & Support Assistant Uninstaller version 22.5.33.3:
https://www.intel.com/content/www/us/en/download/19333/intel-driver-support-assistant-uninstaller.ht...
Restart and install the latest Intel® Driver & Support Assistant tool version 22.5.34.2:
https://www.intel.com/content/www/us/en/download/18002/intel-driver-support-assistant.html?wapkw=int...
In the following link you will find additional details about this topic:
https://www.intel.com/content/www/us/en/support/articles/000026895/software/software-applications.ht...
If the issue remains, please provide the latest Intel® Driver & Support Assistant Uninstaller log file: using File Explorer, search for DSAUninstaller.log
The latest Intel® Driver & Support Assistant log files: using File Explorer: go to folder = C:\ProgramData\Intel\DSA, and zip the Log files or entire folder.
Note: Uncheck "Hide System Files" to see the AppData folder.
Show hidden files
https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Just in case, in the link below you will find the instructions on how to gather those folders:
https://www.intel.com/content/www/us/en/support/articles/000089850/software/software-applications.ht...
Albert R.
c1
All seems to be working now
Thanks for the help
Alberto_R_Intel
c1, You are very welcome, thank you very much for sharing those results.
Perfect, it is great to hear that everything is working fine now in regards to the Intel® Driver & Support Assistant.
Any other inquiries, do not hesitate to contact usgain.
Albert R.
