I've attempted to run Integrator Assistant on my NUC7i7BNH and my NUC6i5SYK, but in both instances it crashes my machine and forces it to restart.
Are there any plans on releasing an updated Integrator Assistant that is compatible with either the NUC7i7BNH or the NUC6i5SYK?
NUC_user2017: Thank you very much for contacting the Intel® NUC communities. We will do our best in order to try to assist you with this subject.
Just to make sure, are you referring to the Intel® Driver & Support Assistant or the Intel® Integrator Tool or ITK?
Any further questions, please let me know.
Alberto R
Thanks for responding Alberto,
As of last month this link used to work:
https://downloadcenter.intel.com/download/18672/Intel-Integrator-Assitant https://downloadcenter.intel.com/download/18672/Intel-Integrator-Assitant
I found it as a result of watching this video:
https://www.youtube.com/watch%3Fv%3DCX-A-FyIV5w https://www.youtube.com/watch?v=CX-A-FyIV5w
I was able to download the installer, but it crashed my machine when I tried to run it.
As for ITK, I've tried to use it to update my splash screen, but it asks for the .BIN file of the OEM Product Key when I tried to set the new JPEG. I'm currently in the middle of trying to learn the command line code I need to use in OA3Tool.exe so that I can create that .BIN file, but it's been slow going due to lack of spare time.
Any suggestions on getting the splash screen graphic changed out without having to worry with the injection of the .BIN file through ITK would be greatly appreciated.
NUC_user2017: You are very welcome. In regard to the Intel® driver and support assistant, we are currently working in fixing some problems with the tool.
In reference to your second question, please download the zip file on the link below, verify the PDF file on page 13 for the steps to update the splash screen:
https://downloadcenter.intel.com/download/26307/NUCs-Intel-Integrator-Toolkit https://downloadcenter.intel.com/download/26307/NUCs-Intel-Integrator-Toolkit
Alberto R
Are you using ITK 6? If you are using ITK 5 in Windows then it will not work correctly on NUCs from the last few years and later. The only supported version is ITK 6.1.6 at the moment. This is an EFI Shell program for setting SYSTEM and CHASSIS SMBIOS fields and changing the Splash Screen graphic and adding an OA3 OEM Windows Product key BIN file to the BIOS.
If all you want to do is change the splash screen the program should not be asking for a BIN file at all. It needs a JPEG or GIF or BMP I believe.
The OA3 BIN file I think can be created using the OPK from Microsoft.
https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/oem-deployment-of-windows-10-f... OEM deployment of Windows 10 for desktop editions | Microsoft Docs
Yes, 6.1.6. I'm not at a place where I can access that NUC at the moment, but I'm guessing this is the syntax from looking at the user guide:
Please let me know if I am wrong about that or if I'm leaving something out.
Thank you kindly for your reply.
I'm not sure what I've left out, but this syntax gives me an error code that lists examples of syntax usage.
That command is invalid. Remember that the command is for placing a logo image into a .BIO file; it does not support inserting logo into current system's BIOS. Thus, you got syntax error because no specification of .BIO file.
Here is the full syntax of the command:
Where:
"-b" is the flag for the BIOS Update File Creation feature
"-x" is the flag for choosing the name of the BIOS update file that will be exported
"-il" is the flag for choosing the logo file (.JPG) to import
Hope this helps,
Thanks, Scott. That was very helpful. From there, I'd just type "exit" and I'm done, correct?
Also, what's the best method for rebooting back into the visual BIOS so that I can uncheck the UEFI boot option? F1, F2, and F10 bring me back to the UEFI boot.
Please disregard that second question. I was able to go back and turn off the UEFI boot.
