Whenever I try to launch the Hardware Watchdog on my Intel NUC running 18.04 or 16.04 LTS Ubuntu I get:
(I am following this instruction http://www.madore.org/~david/linux/iTCO-wdt-test.html)
On my 7gen NUC with 16.04 it worked, but 8gen NUCs have this trouble. Glad for any help! Thanks
[ 71.325175] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 71.325237] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[ 71.325252] iTCO_wdt: probe of iTCO_wdt failed with error -16
Hello JKipp,
Thank you for posting on the Intel Community.
I understand that you’re trying to launch the Hardware Watchdog on your Intel® NUC 8i3BEK.
Please allow me some days to investigate the behavior you’re experiencing, since the only operating system validated by Intel is Windows 10* 64-bit. You can check that information on the link below.
https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html
Also, have you tried posting this question to the Linux* forum of the distribution that you’re using? You may have answers from users that have encountered the same issue.
Thank you,
Oscar A.
Under Contract to Intel Corporation
Hello Oscar_intel,
thank you for taking a look into this. The hardware watchdog is important for Intel NUC to be used as IoT device.
I have only checked linux forums on this an, but not posted it public.
I have tried out 16.04 LTS, 18.04 LTS Ubuntu, Yocto and Debian OS. All give the same error. 6+ months ago, I remembered testing it with an older Linux Kernel on 16.04 and it worked.
So mostlikely all kernels of the last 6 months and 18.04 don't work on Linux together with 8 Gen NUCs.
Jens
I understand. I have made a bug report to the linux kernel maintainers of itco_wdt. If you could test this on your NUC and also confirm this error. This would help. Thanks
Hello JKipp,
I would like to know if you have any update that you would like to share with us?
Abigail G
Under Contract to Intel Corporation.
I have the same problem with NUC8i5BEH. Neither iTCO_wdt nor wdat_wdt load correctly to create a working /dev/watchdog device. Can you issue a firmware update enabling watchdog device on Linux?
@vvidic Did you find a solution? Also on my Nuc8i5BEH the wdat_wdt loads without any output as error, but no watchdog device is created :-( See also my thread here on intel forum https://forums.intel.com/s/question/0D70P000006VRwX/nuc8i5beh-is-registering-itcowd-watchdog-wronlgy-and-so-watchdog-is-unusable?s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&emkind=chatterCommentNotification&s1uid=0050P000008X0kV&emtm=1571068968521&fromEmail=1&s1ext=0
I am getting same error on brand new Laptop Lenovo P53 with i9-9880H CPU
I have the same with NUC8i5BEH too ... and also opened up an own thread some time ago. https://forums.intel.com/s/question/0D70P000006VRwX/nuc8i5beh-is-registering-itcowd-watchdog-wronlgy-and-so-watchdog-is-unusable?s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&emkind=chatterCommentNotification&s1uid=0050P000008X0kV&emtm=1571068968521&fromEmail=1&s1ext=0
The error matches to infos that can be found at https://www.spinics.net/lists/linux-i2c/msg41504.html where Linux Kernel devs analyzed the tpic and said that it needs to be fixed in BIOS from NUC.
