Community
cancel
Showing results for
Search instead for
Did you mean:
LMadd
Is there a preferred order when installing drivers ?
Jump to solution
I'm thinking of re-installing Windows 10 onto my NUC but wanted to know if there's a preferred order when installing the Intel drivers ?
Does it matter which order you install them ?
Is it best to reboot between each install or only if the installer asks you to ?
Is it best to use the Intel® Driver & Support Assistant or download each one directly ?
Tags (1)
LeonWaksman
1. In my opinion, the driver shall be downloaded from Intel's site and then installed manually. In this forum I saw many cases of false alarms wile installing drivers with the Intel® Driver & Support Assistant.
2. First install the Chipset Driver and Management Engine driver and reboot the computer. Now install all the other drivers (sequence of installation is not important). You may reboot your NUC only once, after the last driver is installed (the installer is asking to reboot after each driver but this is not necessary).
Leon
LeonWaksman
Leon
n_scott_pearson
Super User Retired Employee
It is best to install the Chipset Software package first. For WiFi, install Bluetooth package before Wireless package. Other than that, it doesn't matter; I typically do it in alphabetical order.
I reboot only once after installing all packages. During each package install, simply say no if it asks for a reboot.
I have always done it manually. IDSA is getting better and better, but there are some fundamental issues in a number of packages that prevent the process from working cleanly.
Hope this helps,
LMadd
Many thanks to you both.
I wasn't sure if the IDSA was robust enough yet, I'll download them manually.
