Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11888 Discussions
NUC7I5BNH problems with 10-bit / HDR
AGijs
I have a NUC7I5BNH miniPC (Win 10, 64 bit, Fall Creators update, latest Windows updates, latest BIOS, latest drivers, latest HDMI firmware as of 24 Jan 2018) that was until recently connected to a Sony KDL-52Z5800 TV (1080p TV).
Last week, I exchanged my TV with a Sony KD-65A1 4K OLED HDR TV.
I connected the NUC with the HDMI 2 input of the Sony KD-65A1, using an Ultra HD 2160p 60Hz 18 Gbit/s HDMI 2.0b specified cable (tried 2 different ones!).
On the Sony TV, I enabled 'HDMI Enhanced mode' which allows to view 4K or HDR pictures at 18 Gbps according to http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/136957/~/how-to-set-up-your-sony... http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/136957/~/how-to-set-up-your-sony...
The NUC is set to 3840 x 2160 at 60Hz in the Intel Graphics Control Panel. Colour input range is set to 'Use driver setting' > 'Full range'.
I have 2 problems:
  1. Colour banding: indeed, when checking in Windows in 'HDR and advanced colour settings', the colour depth is 8-bit and the colour format is YCbCr420. I don't get the NUC to output 10-bit, whereas both the NUC and the Sony TV should be compatible with this colour depth.
  2. HDR: in Windows in 'Display' the 'HDR and advanced color' toggle is visible but after I try to turn it on and confirm the new settings, the toggle is again on 'Off'. In the 'Video playback' settings page, the toggle 'Stream HDR Video' is greyed out.
Any help in sorting out those 2 issues would be greatly appreciated. According to my understanding, but the NUC7I5BNH and the KD-65A1 should be able to handle 10-bit / HDR.
Please find the necessary support files attached.
Community Manager
Hi Nuckelback,
I could see that you have been facing some graphics issues related to the HDR and Color Depth, let me apologize for this inconvenience and help you out with this in order to figure out the root of the issue and fix this once for all.
I understood that you have a Sony KD-65A1 4K OLED HDR TV using the resolution 3840 x 2160 at 60Hz.
According to the first issue;
I was doing some research in my end and I would like to share with you a table information that will include all the resolution, color depth and bit that your current set up will support, please check the table information below:
As you could see your current set up will support YCbCr420 in 8 bit only.
Related to the second issue;
I was checking the DxDiag information that you already provided to us and I noticed that you have installed the Graphics Driver Version: 23.20.16.4877. Nevertheless, There is a new version available for you.
I would like to recommend you to install the latest Intel® Graphics Driver Version in order to make sure that your system will have the compatibility with the feature HDR.
Please check the link below in order to download the driver.
https://downloadcenter.intel.com/download/27412/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?pr... https://downloadcenter.intel.com/download/27412/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?pr...
Please let me know your outcome and I will be more than happy to assist you with something else.
Emeth M
AGijs
Hi Emeth,
Just to make sure, I first deinstalled Intel SGX and Intel ME. I then reinstalled Intel ME and Intel SGX. In the BIOS, Intel SGX is enabled, with 128M memory as recommended in the Intel SGX readme file. I then completely deinstalled the graphics driver and reinstalled the lastest graphic driver for which you provided a link.
Regarding the first issue, I'm aware of that table and of the table at hdmi.org:
So, putting these 2 tables together, I should be able to output 10-bit with any of the following settings:
  • 3840/60p RGB 4:2:0
  • 3840/30p RGB 4:4:4
  • 3840/30p YCbCr 4:2:2
So, my question is: how do I set any of these configurations?
By the way, when I set 3840/30p with the Intel Graphic Control panel, I'm still stuck with 8-bit, this time with RGB (4:4:4, I suppose?) color space, see image attached. How come that it is still not 10-bit ???
Regarding the HDR issue, no change with the new driver. I can't still not turn it on (not with 3840p60 and not with 3840p30).
In other words, I'm not a step closer.
Community Manager
I understood your point, I was checking your system information and I see that you are currently using 3840 x 2160 at 60Hz.
I would like to recommend you to set up a different resolution such as; 4096 × 2160 that is a 4K Native resolution. As a matter of fact, your current resolution is Ultra-HD.
Once you already change the resolution please try to use the 10 bit.
As well, please let me do some research on my end in order to recreate the scenario related to the HDR issue.
Emeth M.
AGijs
Sorry, 4096 × 2160 is a no-go as this PC is used as a home theater PC and should use the native resolution of my TV (which is 3840 x 2160 at 60Hz) and not the other way around.
In the meantime, I had some progress: I disconnected and reconnected the TV from the power socket and thus forced the Android operating system of the TV to restart. After having done this, if I set the PC to 3840 x 2160 at 30Hz, I get 10-bit output with RGB color space (see image 2160p30.jpg) and the HDR toggle can be switched on.
As the native resolution of my TV is 3840 x 2160 at 60Hz, and taking into account the bandwith limitations of HDMI 2.0, I assume the best option for the PC settings would be 3840 x 2160 at 60Hz, 10-bit with RGB 4:2:0.
From the moment I change the PC settings to 60Hz, I fall back to 8-bit color depth (see image 2160p60). In order to stay at 10-bit color depth, which settings should I set in the Intel Graphics Control panel to achieve RGB chroma resolution 4:2:0?
As you can see in this thread /thread/111279 https://communities.intel.com/thread/111279 , I'm by far not the only one asking that question !!
Community Manager
I was doing some research on my end and I tested the same NUC model on a 4K HDR TV.
I used the HDMI 2.0a cable and I could be able to recreate the scenario successfully.
As a matter of fact, I was able to enable the HDR feature in Windows 10 64 bit in YCbCr420 in 10 bit on 4096 x 2160 and as well on 3840 x 2160.
4096 x 2160 / 64Hz / 10-bit / YCbCr420.
3840 x 2160 / 60Hz / 10-bit / YCbCr420.
I would like to suggest you test your NUC with a different HDMI 2.0 Cable and if you have the possibility to use a different video port such as Type-C just to make sure would help in order to figure out more information even though if you have the chance to test a different 4K HDR TV just in order to double check your environment would be great.
Emeth M.
AGijs
I tried several HDMI 2.0a cables, without success.
At 3840 x 2160 / 60Hz I get 8-bit RGB (this would be 4:4:4, because I can read all lines of the test image (attached)). Enabling YCbCr in the Intel Graphics Control Panel doesn't change this, the PC remains in RGB (also when restarting the TV and/or PC).
At 3840 x 2160 / 30Hz I get 10-bit RGB (again, this would be 4:4:4, because I can read all lines of the test image (attached)).
So, I repeat my question: in order to stay at 10-bit color depth at 60Hz, which settings should I set in the Intel Graphics Control panel (or anywhere else in Windows 10) to achieve RGB 4:2:0 or YCbCr 4:2:0 ???
Community Manager
According to this table if you would like to have set up in your system 10 bit at 60Hz.
You should have this resolution: 4096 x 2160.
4096 x 2160 / 60Hz / 10-bit / YCbCr420
AGijs
I'm losing my patience here:
  1. I've previously told you that 4096 x 2160 is not an option; I need to set it to the native resolution of my TV which is 3840 x 2160 / 60Hz
  2. In your previous message, you mentioned yourself that you were able to get an output of 3840 x 2160 / 60Hz / 10-bit / YCbCr420
  3. Despite of me putting my question in bold in my previous message, and thus impossible to overlook, you STILL haven't answered my plain and simple question: which settings should I set in the Intel Graphics Control panel (or anywhere else in Windows 10) to achieve 3840 x 2160 / 60Hz / 10-bit RGB 4:2:0 or YCbCr 4:2:0, AN OUTPUT WHICH YOU APPARENTLY WERE ABLE TO ACHIEVE IN YOUR SETUP, SEE POINT No. 2
Community Manager
I understood your point and I really do apologize for the inconvenience that you have been facing moreover when I recreated the issue in our labs I was able to set up the resolution 3840 x 2160 / 60Hz / 10-bit / YCbCr 4:2:0 that you are looking for without any trouble.
In this case, I am considering that there is a lag in your system related to the TV/Monitor that is not allowing you to have that configuration.
As a matter of fact, I recreated the issue today just to make sure that I was not missing something. Let me share with you all the details that I gathered from our labs.
Emeth M.
Community Manager
You will see in this picture on your left side the HDR and advanced color settings.
On your right side, you will see the Display information such as Device and Driver Information.
Emeth M
Community Manager
This picture that I am sharing with you will provide you that I was able as well to set up the HDR using the resolution 3840 x 2160 and also it will show you the system information of the NUC that I used.
Emeth M.
Community Manager
I would like to share with you as well the DxDiag of the system.
Emeth M.
Community Manager
Finally, I would like to share with you the Intel Graphics Information from the system that I used.
Emeth M.
Community Manager
I am wondering if you have any other questions or if you still need more assistance with this issue.
Emeth M
AGijs
Your picture lab2.png made me try out the combination of:
  • switch HDR on
  • set scaling to 300%
This finally provided the sought after colour space YCbCr420 with 10-bit color depth at 3840 x 2160 at 60Hz (see picture attached).
Previously, I had scaling set to 100% and this gave bad colour artefacts in text when switching on HDR, so I never went as far as checking the colour space and bit depth in that configuration.
With scaling set to 300% and HDR on, the color artefacts are gone, so all is fine.
Thanks for your help.
psupe1
Ist there any solution? I'm not getting it. do I need an it master to use my NUC7i5BNK with 4k 60hz and 10bit or are we beta user? even finding the information is nearly impossible, the settings in the control panel are a joke and there are at least 1000 pages in forum to read with similar problems
no 10bit in any set up... and yes, all is up to date and cables are 18gbps
W10, 64 all up to date...
additionally the display and sound interruptions, but that's another topic..
any solution would be much appreciated! thx!
Community Manager
Hello petesuper
Thank you for joining the thread.
I recommend creating a new thread, please make sure you add the information of the system model and specs, model of the hardware that is presenting the problem and detail information of the problem that you are having, plus all the information that you have added to this thread, so we can get more information about the problem.
Please attach to the new thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Thank you; hope to hear from you soon.
Leonardo C.
Under Contract to Intel Corporation
MSchw36
Hello, same problem here with my NUC NUC8I7BEH2. I'm stuck on 8-bit color in SDR, or "8-bit with dithering" in HDR. No HDR passtrough in any way. Also, my NUC is plugged to a Bravia TV, I've got lagging mouse in "general scene" when I let the TV chose the scene automatically. Mouse is fine if I use "game scene" manually. As I need to have HDR passtrough, I have to let my TV on auto-scene if I want it to change automatically to HDR scene whenever I play some HDR content. Can't understand why my mouse is lagging in "General Scene" and not in "HDR scene" or "Game scene".
Is there a solution to activate 10-bit color in SDR ?
Is there also a solution for mouse lagging in certain tv modes ?
I've looked for everywhere on the internet, nobody seems to have found a solution for these two problems on their NUC.
Should I buy a USB type-C to HDMI adapter to fix these two problems or at least one of them ?
Sorry for my bad english, I am french.
