Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Nuc with Dual 4k Displays?
I recently got a couple of the Dell 4k displays and cant seem to get them to work on my nuc. When i daisy chain them i can only get the second one to do 1024x768. I know Dp 1.2 can do it since if I hook them up to a normal computer it works. The only way so far I can get full res on the nuc is one on dp and the other on hdmi.
Should this work? it would seem the spec supports it since they only run at 30hz each
Tags (1)
Highlighted
also i have the latest bios and drivers installed
Highlighted
Hello Drvcrash, I do understand the inconvenience you are facing however it is very important for us to know which is the model number of the NUC you are using?
When you're doing daisy chain on the 2 monitors, what kind of adapter are you using?
As you mentioned it, your configuration will give you full resolution only when the 2 monitors are connected directly to the ports.
