Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11988 Discussions
Performance options are not editable / changeable in BIOS
LKoiv1
Just got a NUC8i7BEH and wanted to set RAM to an XMP profile (or even dial in some settings manually), but the options in Advanced->Performance->Memory are all grayed out / disabled. I cannot alter any parameter (and the default settings are quite bad) and netither do I see any option for selecting an XMP profile.
Is there some "check this box to enable the alteration of BIOS values" somewhere?
I updated to the latest BIOS available yesterday using "Intel Driver Assistant" but it made no difference.
Anyone knows what is going on?
Thanks!
David_V_Intel
Hello LKoiv1, Thank you for posting on the Intel ® communities. In this case the behavior you have mentioned is expected, the option to change the settings of the memory performance or create XMP profiles is not available for the unit you have. This has been tested on-site as well, this Intel ® NUC does not allow us to change the settings which means it is an expected behavior. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
