Intel® Optane™ Memory
Comunicados
1388 Discussões
Can't enable Intel optane Memory
JMara5
Principiante
6.495 Visualizações
As the title suggest I can not enable the module through software.
I have attached all the ssu files and the logfiles as you have requested. Thank you for your help.
13 Respostas
Funcionário
3.664 Visualizações
Hi Bananabug,
Thank you for contacting our support community. We understand your situation regarding the Intel® Optane™ Memory that is not detected.
In order to better understand your situation, could you please please let us know the specific M.2 port that your Intel® Optane™ Memory is connected to the motherboard. Also, please let us know the specific SATA port your HHD is connected to the motherboard.
We look forward to hearing back from you.
Junior M
JMara5
Principiante
3.664 Visualizações
I wasn't happy with the way the operating system installed so I redid that. I think now the card is being recognized here however it is stating that
Here is a screenshot of my disk manager and device manager.
I get the above error after rebooting for the first time and now everytime I run the Intel Optane Memory software.
If you require any additional information I am more than happy to provide it
Sorry almost forgot - The Sata drive is on P5 - This I can easily move. The Optane memory is on M2.1 . Easily moved as well.
John /// Banababug
Funcionário
3.664 Visualizações
Hi Bananabug,
Thanks for the information provided.
We recommend you to check the following BIOS configuration:
1- go to Boot\CMS (Compatibility Support Module) and make sure is disabled.
2-Go to advanced\PCH Storage Configuration and check the following information:
A- SATA Mode Selection: Intel RST Premium with Intel(R) Optane(TM) System Acceleration(RAID).
After that please press f10 to save changes and restart.
Please try to access Windows(R) 10 again and try to enable Optane(R)
Please let us know the outcome of your situation.
Junior M.
JMara5
Principiante
3.664 Visualizações
Hello again and thank you for your response.
I did what you asked and I still receive the following error
I took some additional steps to try and resolve.
I removed the software - rebooted and reinstalled the software.
I moved the hard disk to p2 just incase that may have been an issue and removed and reinstalled the program.
Further help will be most appreciated.
Bananabug // John
Funcionário
3.664 Visualizações
Hi Bananabug,
Thanks for the reply.
We recommend you to connect the Intel® Optane™ Memory in the M.2.2 port and also, try to install your HDD in the SATA port 3 or 4.
Juinor M.
JMara5
Principiante
3.664 Visualizações
Hi and thanks for your reply
Did as you requested - moved the sata drive and the Optane memory
Still getting same error.
Look forward to you next suggestion :-)
Bananabug / John
Funcionário
3.664 Visualizações
Hi Bananabug,
We recommend you to try disconnecting your NVidia* video card after that, try to enable Optane(TM).
Also, please let us know if Optane(TM) is detected on BIOS.
We will be waiting for your response.
Junior M.
Funcionário
3.664 Visualizações
Hi Bananabug,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
AMass5
Principiante
3.664 Visualizações
I struggled to get Optane to work for a while, to the point where I gave up for about a month. I was able to get it to work after following the previous steps and moving optane to my M.2.2 port and SATA port to 3. Thank you!
Funcionário
3.664 Visualizações
Hi FrommtheBursar,
We are glad to hear that your situation has been resolved.
If you have further questions then feel free to contact us again.
Junior M.
Kn
Principiante
3.664 Visualizações
Hi banana,
I am having almost the same errors as you. Just so I could follow what you did, you removed the NVidia graphics card?
Funcionário
3.664 Visualizações
Hi Kavs,
We recommend you to disconnect the NVidia* graphics card as suggested by Bananabug.
In case the situation remains, please provide the following information:
-Optane(TM) logs located here: C:\Users\[your user name]\Intel\Logs
-Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility. Run the scan selecting "Everything." Save this report and upload.
-Please let us know the specific ports you are using to connect the Optane(TM) and the drive you want to accelerate. Also, if you have other drives connected then let us know the ports you are using as well.
Junior M.
Funcionário
3.664 Visualizações
Hi Kavs,
Junior M.
Responder
