Intel® Optane™ Memory
Error Enabling Optane
RSant4
Recently i had a issue with my pc that i resolved but i had to add windows again and delete all my drivers. The last time this happened i installed the optane drivers quick and easy, but this time when i downloaded it and pressed enable an error message came up and said "An error has occurred" i went into the UEFI and turned the optane off to see if that was the problem only to find my computer restarting several times and not loading. so i turned it back on and reinstalled the drivers but the same thing keep happening. then i installed intel RST and got a message with a caution sign over my optane. If someone could please help me that would be great.
n_scott_pearson
Regarding your issue, we need more information about your system. Please download and run this utility and attach the results file to a subsequent post: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
RSant4
n_scott_pearson
Thank you. An Intel Customer Support representative will look over your information and get back to you.
RSant4
Hello Geenie555,
Thank you for contacting Intel Technical Support.
In order to further assist you we need you to provide us with the following information:
  • Picture or screenshot of the error that you are experiencing when running the RST and the Optane tool.
  • A screenshot or picture of your "Disk management "showing all your drives.
  • We will like to know if you disable your Optane memory before reinstalling your operating system.
We will be looking forward to your reply.
Josh B.
RSant4
this always pops up when i try to enable it.
Hello Geenie555,
Thank you for your reply and the screenshot provided.
  • Picture or screenshot of the error that you are experiencing when running the RST tool (you need to uninstall the Optane memory tool first).
Josh B.
RSant4
Hello Josh B.
I will be able to provide you with the rest of the details in about a week. Just so you dont think i forgot and wasted your time.
Geenie555
Hello Geenie555.
Thank you for your reply.
Please take your time and if you need further assistance please do not hesitate to contact us.
We will be looking forward to your reply including the information requested in our previous post.
Josh B.
Intel Customer Support.
Hello Geenie555.
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication and we would like to know if you were able to extract the information requested in our previous interactions.
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
Josh B.
RSant4
Hello Josh B.
Sorry about that i just got back from my vacation. Should i uninstall intel optane memory and install the RST?
Hello Geenie555.
To answer your question:
"Should I uninstall Intel Optane memory and install the RST?"
• Yes, please uninstall the Optane memory software and install the RST tool.
Josh B.
RSant4
Hello Josh B.
here is the screenshot of the rst
Hello Geenie555.
Josh B.
RSant4
Hello Josh B.
Can you please explain to me what the disk management is and where?
Thank you
Hello Geenie555.
Disk Management is a system utility in Windows that enables you to perform advanced storage tasks. Please find some ways to open the Disk Management below:
Way 1: Open it from the Quick Access Menu.
Right-click the bottom-left corner (or Start button) on the desktop to open Quick Access Menu,
and then choose Disk Management.
Way 2: Access Disk Management via Run.
Use Windows+R to open Run, type diskmgmt.msc in the empty box and tap OK.
Feel free to use this link as a reference on how to access to the Disk Management:
https://www.isunshare.com/windows-10/7-ways-to-open-disk-management-in-windows-10.html
• Please take a screenshot of the Disk Management showing all the disk and partitions.
Josh B.
Under Contract to Intel Corporation
Third Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use, you agree that you must evaluate, and bear all risks associated with, the use of any third party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site specific terms.
RSant4
Here is the screenshot of my disk management. I did disable the intel optane when i reinstalled my operating system because i have had some issues before and i called the company that sold me the pc and they said to disable Intel Rapid Storage in the bios.
Hi Geenie555,
After checking the information in the thread I'm not sure if you have disabled the Intel® Optane™ Memory from the application or if you actually disconnected it physically from your system without disabling it first from the application. I'm asking because it doesn't appear in the SSU report that you provided previously nor in the Disk Management screenshot.
On the other hand, from the Disk Management screenshot, I noticed that you don't have a reserved unallocated space of at least 5MB in your drive. This is necessary for the module to work properly. However, let's focus on this later and try to figure out why the module doesn't appear in your system.
If you were able to install the module previously then you should have your BIOS properly configured, but we can check it just to be sure. These are the settings you should check in your BIOS:
  • SATA Mode Selection set to Intel RST premium with Intel Optane.
  • M.2_X PCIE Storage RAID Support set to Enabled.
  • CSM set to Disabled.
Since you are using an ASUS* motherboard, you can check the following guide for additional details about where these settings are in BIOS: http://dlcdnmkt.asus.com/microsite/Optane-Memory-SOP.pdf
Additionally, you should have had installed your Windows OS* using a GPT partition style. Could you please confirm this?
If everything is properly set and you have the Intel® Optane™ Memory connected, could you please check your Device Manager to see if the module is recognized? Please attach a screenshot of it.
I'll be waiting for your response.
Have a nice day.
Diego V.
RSant4
So do you think i deleted a drive without enough space for the optane?
Hello Geenie555.
"So do you think I deleted a drive without enough space for the Optane?"
From the Disk Management screenshot, we noticed that you don't have a reserved unallocated space of at least 5MB at the end of the drive. This is necessary for the module to work properly. Since you reinstalled your OS seems to be that at the moment of partitioning your C: drive you did not reserve that space.
"I did disable the Intel Optane when I reinstalled my operating system because I have had some issues before and I called the company that sold me the pc and they said to disable Intel Rapid Storage in the bios."
This could be one of the reasons why your system is not able to detect your Optane memory. Please, back up your information and follow the http://dlcdnmkt.asus.com/microsite/Optane-Memory-SOP.pdf ※Installing OptaneMemory on RAID mode OS guide to reinstall your OS and do not forget to leave a reserved unallocated space of at least 5MB at the end of the drive at the moment of partitioning your HDD.
Based on the "/servlet/JiveServlet/download/563548-191037/Screenshot (6).png Screenshot (6).png" you shared with us there is still some metadata in the Optane memory and we advise you to run the "Clear metadata" option before reinstalling your OS using the Intel RST software.
We hope you find this information useful.
Josh B.
