- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
My system specs:
Motherboard: Asus B250M-A
CPU: Intel i5 7400
Gpu:EVGA Gtx 970
Boot: 120 gig SSD
Media drive: 2TB baracuda
Optane: 32gig (it is in the correct slot as per the motherboard manual)
Windows 10 PRO x64.
Launch CRM is set to Disabled
Drives enabled with hot plug DISABLED.
Sata M.2 selection mode set to RTS control enabled.
These are my Current drives, as listed.
The drive I WANT to accelerate (secondary SATA HDD)
Error i get (0xA005004B)
as per trouble shooting, I tried to accelerate my boot / Data SATA SSD
I get this ERROR on my SSD data.
AND I get this error if i try to install using OPTANESETUP.EXE
(0xA0050055)
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello KennethMoreira85
Thank you for contacting Intel Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory Series (32GB, M.2 80mm PCIe 3.0, 20nm, 3D Xpoint). If we infer correctly we advise you to take the following information into consideration:
- Based on the "https://www.intel.com/content/www/us/en/support/articles/000026040/memory-and-storage/intel-optane-memory.html Software and Platform Support for Intel® Optane™ Memory"
- We advise you to contact Asus in order to confirm that you have the latest available version of your BIOS installed on your system.
On the main time, we will be reviewing the information you provide us and we will be replying to this post as soon as we have an update.
Thank you for your patience and understanding.
Josh B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks for response, ya I did a bios update prior to hardware installation. Used the built in updater
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
intel_admin. is there anything else i can try while you guys review the log or is it just a matter of waiting at this point?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
intel_admin can i get some help please? I've been struggling with this for almost 18 hrs. reformatted both drives and lost everything once by accident trying to get it to work.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello KennethMoreira85.
Thank you for your reply.
We are working on trying to reproduce your issue in our labs and as soon as we have an update we will be replying to this post.
Josh B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
tried to boot via ahci mode and it gives me blue screen. No boot device. ) every little bit of Information I can give I will)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
update
i reformatted with unallocated space on the end of the c drive. I still CANNOT get optane to work with my D drive (2TB)
(error 0xa005004b)
however, it DID enable properly now on my C / Data drive.
so we are getting there.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello KennethMoreira85,
We are glad to hear that you were able to accelerate your primary drive, but our main goal is to try to accelerate your secondary/Data drive in order to try to accomplish this please follow these recommendations:
- Please low-level format your Secondary/Data HDD in order to write zeros and to try again to accelerate your secondary drive(remember to back up your information first).
Here are some free tools you can use to run a low-level format:
http://www.hdat2.com/ HDAT2*http://www.killdisk.com/ KillDisk*http://www.dban.org/ DBAN*
-If this does not work our only recommendation is to backup and to reinstall your OS by following the guide below:
*Please, notice that this guide was created using Intel® products only and we cannot assure you that it may work if you have components from different manufacturers.
In order to perform a Windows fresh installation and a secondary/data drive acceleration in a system with a system BIOS that is compatible with secondary/data drive acceleration and starting in RST premium following the steps below:
Intel recommends that a full and verified backup of data be performed before attempting to apply this process; see "The Importance of a Backup Solution" at:
http://www.intel.com/content/www/us/en/support/server-products/000007914.html http://www.intel.com/content/www/us/en/support/server-products/000007914.html.
• Access to your system BIOS and access to the following settings:
Peripherals / Intel®RST RAID driver
Once here check if the HDD that you are going to install your OS and the Intel® Optane™ Memory are detected properly.
• Turn your PC off and disconnect all the other hard drive devices from your system including the Optane and check that your OS HDD is the only storage device in the system.
• Start the Windows setup process and select the Custom: Install Windows only(advanced option) and select the Load driver option.
• Download the driver from the following link and unzip the file on the USB thumb drive:
https://downloadmirror.intel.com/28072/eng/f6flpy-x64.zip https://downloadmirror.intel.com/28072/eng/f6flpy-x64.zip
• Click on browse and select the folder where the drivers are located and the installer is going to load the list of available drivers.
• You are going to be offered with 2 options, please, select the "Intel® chipset SATA/PCIe RST Premium, Controller"
• After loading the necessary drivers it should show your HDD storage device.
• Continue the setup process as usual by selecting the drive that you want to use as primary and accept if the system requests to create more partitions (remember to left some space at the end of the drive).
• After the setup process is completed boot to your new Windows installation and completes the required information to access your desktop and turn your PC off
• Connect your Intel® Optane™ Memory and the secondary SATA drive that you want to accelerate and turn your system back on.
• Check on the Disk manager tool that your drives are detected properly.
• Download and install the latest https://downloadcenter.intel.com/download/28072/Intel-Optane-Memory-User-Interface-and-Driver-for-System-Acceleration Optane memory software.
• Restart your system as requested at the end of the setup process.
• Access to the Intel® Optane™ Memory User Interface and check the acceleration settings.
• Try to accelerate your seconda...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
being that I've now reformatted both drives twice this month, and re installed all the files and games etc .
I am pretty much at my ISP data cap for the month, I'll try this walkthrough in October and respond with my results. Thanks.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Got it.
removed my SSD / OS from the pc
Inserted window 10 media usb
made sure bios set to RST controlled SATA and CLM was Disabled
Formatted my HDD with 100 mb unallocated space at the end
installed the drivers "Intel® chipset SATA/PCIe RST Premium, Controller"
installed windows on the HDD
installed optane and ENABLED it.
it worked!
re connected my Data drive / SSD with windows also on it
set my bios to boot from the SSDs copy of boot mananger /windows.
checked in the optane program, the HDD is STILL enabled as accelerated.
so I now have my OS on SSD and Optane accelerating the 2TB HDD.
intel_admin
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We are glad to hear you were able to resolve the issue you were experiencing and we would like to know if you need further assistance or if we can close this case?
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
We will be looking forward to your reply.
Josh B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case?
Josh B.
Intel Customer Support.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
seems to be working . you can consider this issue resolved. Ty
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
s the title says, i bought an intel optane 16gb module, i fixed the bios settings and that now my problem is why it suddenly says my hdd isnt compatible with intel optane anymore, it didnt say that before i fixed with the bios.https://origin.onl/ Origin
16 gb intel optane
motherboard: GA B250 DS3H https://audacity.onl/ Audacity
i3 7350k kaby lake
all my components support intel optane.
i need help because my bios doesnt have a remapping setting because i believe the problem is that my hdd needs like 5mb at the end of the hdd but i dont know how to fix with those things https://findmyiphone.onl/ Find My iPhone
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello bimaloy30,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory Series If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, and we would appreciate if you could, please, reply to this post with the following, important, basic information:
The SSU logs.
1- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t and download the software.
2- When finished downloading it, open it.
3- Mark the box "Everything" and then click "Scan.
4- When finish scanning, click "Next."
5- Click on "Save."
6- Attach the file to your reply.
- A screenshot of the "Disk Management" of windows showing all your HDDs and partitions.
- A screenshot of the error you are experiencing.
- We advise you to back up your information and to partition your HDD and to let a reserved unallocated space of at least 5MB at the end of the main drive. This is necessary for the module to work properly. This can be accomplished by the usage of application designed for this purpose (several are free and include manuals on how to do it).
- We advise you to follow the recommendation available in your https://www.gigabyte.com/MicroSite/454/intel-optane-ready.html OEM website section B-2 related to the BIOS settings and let us know the results.
Josh B.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi bimaloy30,
I'd like to know if you still need help with this.
Diego V.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
