Intel® Optane™ Memory
1391 Discussions
Hello, I purchased Intel optane 32gb and a PCIe m.2 ssd adapter. Installed in HP Z820 Workstation. While try to install Intel Optane software in Windows 10 Pro 64bit It giving me error message. Thanks.
BDas1
AlHill
Your processor is E5 2670. Do you see it in the list you provided? No, you do not.
OPTANE is not supported on your system.
Return the Optane to the seller for a refund.
Doc
AlHill
What error message?
Do you know for certain that your device supports Optane?
Download, run, and attach the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
BDas1
This is my bellow system information:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Xeon E5 2670 @ 2.60GHz 50 °C
Sandy Bridge-EP/EX 32nm Technology
Intel Xeon E5 2670 @ 2.60GHz 60 °C
RAM
32.0GB DDR3 @ 797MHz (11-11-11-28)
Motherboard
Hewlett-Packard 158B (CPU0)
NV Surround (5760x1080@59Hz)
3071MB NVIDIA GeForce GTX 1080 Ti (Gigabyte) 36 °C
Storage
231GB LSI Logical Volume SCSI Disk Device (SAS(Serial Attached SCSI) )
1863GB Western Digital WDC WD20EFRX-68EUZN0 ATA Device (SATA ) 33 °C
27GB INTEL MEMPEK1W032GA (Unknown (SSD))
931GB Western Digital WDC WD10EZEX-00WN4A0 (SATA ) 34 °C
931GB Western Digital WDC WD10EZEX-08WN4A0 (SATA ) 34 °C
931GB Seagate ST1000DM003-1SB10C (SATA ) 32 °C
Optical Drives
hp DVD A DH16ACSHR ATA Device
Audio
SB Recon3D PCIe
Error Message : Intel Optane memory requires motherboard with a supported Intel 200 Series Chipset(or later) to be enabled.
I ran the Intel System Support Utility, save and attached the information file herewith.
I would appreciate help to resolve the issue.
AlHill
Well, there you have it. You have a X79 chipset, which is too old and does not support Optane. Does HP provide any documentation about their motherboard to the contrary?
And, you need a 7th gen processor or later:
https://h30434.www3.hp.com/t5/Desktops-Archive-Read-Only/Intel-Optane-Support-in-ZWorkstation/td-p/6147206
Doc
BDas1
Yes, please refer to below link. They mentioned it. Please do have a look.
https://support.hp.com/in-en/document/c05591811
AlHill
Yes, but did you look at the link I provided? Show me, specifically, where it says your z820 is supported.
And, your processor is from 2012 - long before the 7th gen processors required to support Optane.
https://ark.intel.com/content/www/us/en/ark/products/64595/intel-xeon-processor-e5-2670-20m-cache-2-60-ghz-8-00-gt-s-intel-qpi.html
Doc
BDas1
So you basically saying it will not support at all.
or
Any driver like Intel RST will not able to support for this ?
Well i do not think so, there must be a option to use it.
thanks.
AlHill
I am saying you need the proper processor and chipset, which you do not have.
https://www.intel.com/content/www/us/en/support/articles/000026040/memory-and-storage/intel-optane-memory.html
Doc
AlHill
Doc
Santiago_A_Intel
Hi BDas1,
Greetings from Intel® SSD Support.
This is a friendly reminder your case remains open, awaiting for your reply.
Please let us know if you might need further assistance.
Have a nice day.
Santiago A.
Under Contract to Intel Corporation
