Intel® Optane™ Memory
Intel Optane Memory issue
DA9
I was trying to was installing an SSD into my system so i removed the Intel Optane Memory m.2 card. Before booting i realised i may need to delete the drivers first so i reinstalled the Intel Optane Memory and booted up the PC. it made it past post but a blue screen with Stop Code ‘CRITICAL_PROCESS_DIED’. How do i fix this problem and boot my pc.
LeonWaksman
1. Before removing Optane Memory, you should disable Optane first.  Since you didn't, The BCD in Windows is corrupted now.
2. You should repair/restore the BCD section and your computer will boot without Optane. There are few methods to repair BCD. Either from Advanced Menu and Command Prompt or by using third party tool, like AOMEI Partition Assistant. Here you have some examples.
Leon
