Intel® Optane™ Memory
1391 Discussions
Intel Optane can't be able. Error 0xA005004E
DDinh6
Xin vui lòng giúp đỡ. Tôi nhấp vào "enable" Intel Optane Memory. Chương trình chạy các "bộ nhớ Intel Optane App chạy vào vấn đề" Lỗi 0xA005004E ". Lỗi này không có trong danh sách lỗi vì vậy tôi không biết làm thế nào để sửa nó.
Hi dinhmanhdat,
Thank you for contacting our support community. As per out translator tool, we understand your situation regarding the Intel® Optane™ Memory.
In order to better understand your situation, could you please confirm the following information:
*Could you please confirm the brand and model of the boot drive you are trying to accelerate?
*Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility. Run the scan selecting "Everything." Save this report and upload.
We look forward to hearing back from you.
Junior M.
Hi dinhmanhdat,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
